POWER WILL NOT STAY ON. IT GOES OFF IMMEDIATELY WHEN TURNED ON
TV POWER WILL NOT STAY ON TURNS OFF IMMEDIATELY WHEN TURNED ON. HAD IT HOOKED UP TO A VCR AND THINKING MAYBE THE REMOTE NEEDS PROGRAMMING. GRANDKID TRIED TO GET IT SET UP NOW IT WON'T STAY ON mine started to shut off and on about a month ago...now it wont even power up......I also have a 32" toshiba that did the same thing!!!
    Problem Solver:
  • 5 Answers
I dont think the v c r has anything to do with your problem the fact that it started turning off and back on indicates that there is a shut down problem starting in your tv ,,it turns off for safety reasons it was made to do just this when there is an over voltage problem with your high voltage section of your tv to keep from any fire starting ,this is its only safety ...so the turning off is indicating that it has a power problem ,i think it would be safe also to say that its not the remote either i think you need to cary tv to shop and have it checked by a rep man but if you know how to trouble shoot the problem i would look in the high voltage area for the problem like the voltage being too high an the annode lead ,,,,the red wire is verry high volts be careful,,,,,,, also some toshiba tv had problems in lv power supply from capaciators being leaky ,,,,,,,
Posted on Apr 16, 2009
2 Suggested Answers
  • 4234 Answers
SOURCE: POWER WILL NOT STAY ON. IT GOES OFF IMMEDIATELY WHEN TURNED ON
There are many reasons for this behavior. The CRT is not likely the problem. Perhaps one of the most common is the horizontal output transistor. This is a relatively cheap part and can be replaced easily. Figure on $10 for the part plus the local labor rate for the total repair cost.
Even with today's repair cost, the set may be worth the repair if the picture was good before the failure. A replacement set will be over $200 for sure. This is a judgement call on how much to spend and where. It may be worth the $50 or so to get an estimate from a local service shop.
Keep us posted.
Dan
Posted on Apr 10, 2009
Kids stepped on remote.tv wont stay on-it turns off immediately. tried resetting.still turns off. wont stay on.
Pull the batteries out of the remote, and turn the TV on manually if you can. If it still goes off, your problem is not in the remote.
May 22, 2015 | RCA Audio Players & Recorders
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
Turns on immediately turns off
check for shorted component parts at power supply board like bridge type diode and FET transistor. if those are good, disconnect the connectors that supply going to inverter board and then turn on the tv unit if the light indicator at front panel stay and 24v supply doesn't drop which mean the inverter board was the problem of suddenly turn off.
Sep 01, 2012 | Samsung LN19B650 18.5 in. HDTV LCD TV
When the tv is turned on with the remote control,the red sensor light turns into green and blinks 10 times and the tv comes on, but it goes off immediately.As it turns off ,the sensor light turns into red...
Hi, my name is John. Welcome to FixYa. You have a problem in the D board. I will post what you need to check here, such as the transistors, capacitors etc. thanks for choosing FixYa....John
Nov 30, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
While watching tv it just turned off, we turned it back on but no pictures but there is volume. also to turn it back on we see red light and green light together flashing then it turns off. i just replaced...
MY TV TURNS OFF AFTER WE TURN IT ON IT GOES BACK OFF A FEW TIMES AND THEN STAYS ON. AND WHEN I COME HOME FROM WORK IT STARTS ALL OVER AGAIN, THAT HAPPENED FOR 2 WKS NOW IT JUST GOES OFF YOU ONLY SEE THE GREEN LIGHT ON THE FRONT COME ON(POWER LIGHT) AND IT GOES RIGHT BACK OFF IT WILL NOT STAY ON
Sep 18, 2009 | Toshiba Televison & Video
There is nothing can be done outside the tv. The CRT (cathodic ray tube) is getting to its end (maybe). A couple of tests are posible in the workshop to get the final answer.
Apr 08, 2009 | Philips Magnavox 27MS343S 27" TV
Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Mar 27, 2008 | Televison & Video
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Tv powers on, then switches off immediately
check out ctechnicians.com and find error codes
Oct 07, 2007 | Mitsubishi VS-60607 TV
Televison & Video Logo
327 people viewed this question
Top Televison & Video Experts
Electro Med Services...
