Question about Consew 199R-1A Sewing Machine
Cannot get tension balance correct
I have a Consew 199R-1A. I am using Hemingway& Bartlett thread V-92 on 3 or 4 layers of Sunbrella acrylic canvas. I am using a #22 needle.
The Consew was purchased new, but I cannot get support from the seller.
The tension has not been correct from the time I received the sewing machine shipment, The top thread makes loops underneath the fabric .
I have loosened the bobbin until the thread pulls out easily.
I have tightened the upper tension until I can hardly pull the thread through the tension dial -- in fact I use needle-nose pliers to grip the thread to haul it through! With the tension that tight I can achieve a fair balance to the threads in zigzag mode. I know I should not have to do this, but I don't know what to do!
I believe this would be a wonderful machine if I could get this solved.
Can you help me?
  • shaluam Apr 30, 2009
    Thank you, Mimito7, for your suggestion. I had done what you suggested. I have now taken out the spring and see that it is twisted. Need a new spring, and then the fun begins on getting it correctly back in place. There is no one down here in St Lucia that is any more knowledgeable than I -- but I am not bragging about knowledge!
  • 128 Answers
Try this. reomove thread and bobbin from machine.. Set thread tension to the middle number. Rethread machine carefully making sure the thread is thru the tension wheel. Replace bobbin making sure that thread is thru it's tensioner.
Rule of thumb. Loops on the bottom, problem is on the top. Loops on the top, problem is with the bobbin.
Posted on Apr 20, 2009
Thread a consew 199r-3a
you can google your make and model sewing machine with the word "manual" and you can get one.
Jul 16, 2014 | Consew 199R-1A Sewing Machine
Thread breaking at needle
you need to adjust the tension on the bobbin
Apr 25, 2012 | Consew 199R-1A Sewing Machine
HI problem with Consew 199R-1A. Machine locked up. I just started sewing and it locked up. Needle is fine, fly wheel won't turn more then 1/4 back and forth
Good day!
that problem is usually happen when your machine have clog or no lubrication please try to use oil to lubricate your machine at all moving parts inside.
Thank you and good luck.
Jun 10, 2011 | Consew 199R-1A Sewing Machine
Tension
I answered this a couple days ago but don't know if it went through. I can sew through 6 or more layers of denim with my 226, no problems at all. In my 30 years in the upholstery business I never had a problem sewing leather, vinyl, canvas or multi-layers of fabric. The 226 Consew, the 111W and 211w Singers I had presented zero problems with heavy fabrics - and I don't consider vinyl "heavy".
You need to first of all check threading. If the machine's threaded wrong you're break thread. Also you need to oil under the bobbin case and the bobbin hook and the rest of the parts as well.
Then, loosen thread tension on top by turning the knurled knob that's on the spring that's holding the tension discs. Also loosen bottom tension on the bobbin case by turning the small, left-most screw on the outside of the bobbin case counter-clockwise. Do both with the presser foot down. Pull the thread(s) out and feel the tension. You should be able to pull the threads out with some little effort. Tighten both a little at a time until you get some tension. Run a couple seams and check where the threads meet in the fabric. They should meet in the center. Also check stitch length. If you're using 92 thread (is should be left twist), you should run the machine at about 6 - 7 stitches/inch. I'm running my machine at 5 - 5 1/2 with #69 nylon bonded, and 6 - 6 1/2 with #11 mono.
One more thing; if tension's too loose at the bobbin or top, the machine will jam in the bobbin and thread will break.
Go to www.consew.com and download a pdf owner's manual for free. You need to click on the 224. That machine, the 225 and 226 are the same.
Nov 05, 2008 | Consew 226R-1
Consew 199R-1A Sewing Machine Logo
222 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
