Question about Kenmore Elite 45986 Front Load Washer
E1 pops up after 3 to 4 minutes of drying and turns off
It always starts back up and has good heat your help would be greatly appreciated
    President:
  • 1,489 Answers
Check your vent hose -- may be clogged
Posted on Apr 19, 2009
Husqvarna Model#136 Serial#20033000836 chainsaw. When I first start my chainsaw, it starts on the first or second pull and it will run perfect until it runs out of gas. I have to wait until it cools...
Your fuel octane is GREAT ! Good to hear you are using fresh fuel. Make sure to use Husqvarna HP oil. It makes a difference of the heat generated by the engine.
1) If you can: Do not run the saw dry when cutting. As soon as you have the indication that it is almost dry, stop. Remove the fuel cap to remove pressure in the tank. Allow a 5 minute cool down before refueling.
2) I see your saw is a 2003, you may have debris under the flywheel shrouding restricting air flow: remove the recoil assembly and flywheel cover/shroud under the recoil. (if it has one)
Check to see if debris has gathered around cylinder fins.
Clean with compressed air. The ability for the flywheel to breath means more air to cool the cylinder and lower the overall operating temperature of the engine.
3) Make sure the air filter is clean and area is free of debris.
* Each item may be small, but each one builds on the operating temperature.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Mar 24, 2017 | Husqvarna Garden
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Error Message E1 Dries for 3 minutes then stops and gives the error message
E1 means open thermistor. Clean lint duct assembly and blower. Make sure you have good air stream from the vent outside. If this doesn’t help, replace the thermistor.
Oct 17, 2009 | Kenmore Dryers
Intek 25hp came in with less than half a quart, would not start. I drained, replaced oil, cleaned plugs, it started but about the time I turned the choke off 5 seconds of running the engine started making...
does this engine have an oil filter? some of the smaller hp models do not and use a flipper system to throw oil on valves if you have a filter , then your oil pump may have run dry and burnt out
Sep 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
MCG8000AWW Neptune Drying Center initially has heat, then not
hey u burned the ingniter with all that lint, so just buy it around $100 , replace it and back in business.
Feb 28, 2009 | Maytag MDG21PD Electric Commercial Dryer
Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
Propane Gas Dryer (Whirlpool DUET Front Loader) not drying
huuum At your service!
Did this tech do some wash to the dryer and feel that there was no heat?
He was not a good tech
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Jul 11, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool DU1145XTPPB7
These dishwashers normally have a "Control Lock" mode.  It's in the manual.  It is provided for child safety.  It's often controlled by holding the "No Heat Dry" button for 4 seconds or more -- same procedure turns it on or off.
Feb 25, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Lights blinking and won't clear
the solution #3 should work.. you may want to try again.... first turn off the Breaker to cut power then wait a few minutes then turn back on, then within 6 seconds try (Heated dry)(normal)(heated dry)(normal).. all lights should light up then you know that you are in the service cycle, and the unit should go into a self test and clear the fault. The test take about 30 minutes. let me know if you can get into it...
Aug 25, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Kenmore Elite 45986 Front Load Washer Logo
23 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
