Question about Dryers
Converting 3wire GE Dryer to 4Wire connection
I have an older GE dryer and need to change it to the 4-wire power source. I got the replacement pigtail but need to know how to match the 4 wires to the 3 terminals.
  • phill582 Apr 17, 2009
    thanks. That does it.
  • 1,543 Answers
Remove the wire or metal strap from the center terminal to the dryer frame. Put the white wire on the center terminal. Put the green wire on the dryer frame. Red to one outside terminal, black to the other.
Posted on Apr 16, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg Apr 17, 2009
    Glad to be of service, however, if that indeed answered your question or solved your problem, you should respond with the highest rating, not just a helpful. We do this for free, so appreciate the positive feed back. Thanks.
    President:
  • 1,865 Answers
L1 and L2 are the power conductors. The power source receptacle should have a L1 and L2. The grounded wire on the dryer can go to either of the remaining power source condutors. New Installations now make provisions for an isolated neutral wire
My Gibson dryer has a three prong plug on it.I
The National Electrical Code began requiring 4-prong receptacles for 220-volt residential circuits in 2000, but it doesn't prohibit you from using your older dryer with a 3-prong cord. Instead, it allows you to change the cord so that the dryer can be plugged into a modern receptacle, and the procedure isn't very complicated. Four-prong dryer cords, or pigtails, are available at hardware and electrical supply stores, and usually cost less than $20. To make the switch, you'll need a green ground screw to attach to the dryer body so the machine can be grounded by the ground wire.
1 Unplug the dryer and move it to an accessible spot. Unscrew the plate on the back that covers the electrical terminal with a screwdriver. You'll find the cover on the back of the dryer near the bottom of the machine at the point where the cord exits.
2 Loosen the three terminal screws holding the cord. Before you remove them and take off the cord, note the colors of the screws and the wires attached to them. The screws holding the black and red wires are brass and the one holding the white wire is silver.
3 Remove the ground strap from the silver terminal. It may be a small metal plate or a length of wire connecting the terminal to the body of the dryer. You may be able to pull it out with pliers, or you may have to loosen a screw to remove it. Its function was to ground the dryer, and that function will now be served by the ground wire on the new pigtail.
4 Insert the brass terminal screws into the ring lugs attached to the red and black wires on a replacement pigtail and the silver screw into the ring lug on the white wire. Drive the screws into the same slots from which you removed them and tighten them securely with a screwdriver.
5 Drill a 1/4-inch hole in the body of the dryer within reach of the fourth wire in the pigtail, which is green. Insert a green ground screw through the ring lug on the end of that wire, drive the screw into the hole and tighten it securely.
6 Feed the cord through the notch on the terminal cover plate and screw the cover plate to the back of the dryer.
Things You Will Need
  • Screwdriver
  • Pliers
  • Drill
  • 1/4-inch drill bit
  • Ground screw
  • 4-prong pigtail
Tip
  • There usually isn't room behind the cover plate to install the ground screw. If not, it's acceptable to attach the screw to the back of the dryer outside the plate.
  • Check the grounding with a multimeter before you plug in the dryer. Set the meter to ohms, touch one lead to the dryer body and touch the other lead to the ground prong on the plug. The meter should show less than 10 ohms of resistance.
References
Sep 12, 2014 | Dryers
Tip
Electric Dryer power connections
The supply cord on an electric dryer can be 3 wire or 4 wire,
depending on the existing receptacle. All new construction
must have 4 wire receptacles for dryer hook ups.
At the back of the dryer you will see a set of three
terminals. The outside terminals are for connecting the
outside wires of the cord. In a 4wire hook up, the center
terminal is for the center, insulated, white wire, the
neutral. The bare copper or green wire of the 4wire cord
gets connected above these terminals to a lug or stud on
the body of the dryer. There may be a strap there. For a
4wire cord connection this strap is connected to the stud
only.
The change for a 3wire connection is that the center green
wire of the 3wire cord connects to the center of the three
power terminals along with the grounding strap from the
dryer body above.
on May 05, 2010 | Washing Machines
Tip
How to change your dryer from 3 wire to a 4 wire power cord. (short and simple)
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
on May 23, 2009 | GE DBSR453EBWW Electric Dryer
Need instructions on wiring for a 4-wire pigtail on a GE Dryer Just moved, the new place has the new 4 prong outlet so I replaced my pigtail with the new 4-wire one. Need wiring instruntions for the colors...
put the white in the middle,red on one side black on the other doesn't matter what side or just copy the old cord,now you need to ground it with the green wire,take off a screw on the back of the dryer near the other three and attach the green ground wire to it and screw it back in,the green wire just has to touch the metal frame to ground it
Mar 14, 2010 | GE Dryers
Eletric cord installation
The supply cord on a dryer can be 3 wire or 4 wire, depending on the existing receptacle. All new construction must have 4 wire receptacles for dryer hook ups.
At the back of the dryer you will see a set of three terminals. The outside terminals are for connecting the outside wires of the cord. In a 4wire hook up, the center terminal is for the center, insulated, white wire, the neutral. The bare copper or green wire of the 4wire cord gets connected above these terminals to a lug or stud on the body of the dryer. There may be a strap there. For a 4wire cord connection this strap is connected to the stud only.
The change for a 3wire connection is that the center green wire of the 3wire cord connects to the center of the three power terminals along with the grounding strap from the dryer body above.
Dec 05, 2009 | KitchenAid KEHS01P Electric Dryer
Need to connect 4 wire pigtail to replace 3 wire
The following link explains how to convert a 3-wire to a 4-wire power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the Neutral (White) and the Ground (Green or Bare Copper) wires are terminated at the terminal block. In a 4 -wire configuration these wires are independent of each other. In other words, neutral does NOT get grounded.
If you have any questions, please let me know. I hope this helps you.
Oct 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool LE5795XPNO 3-wire to 4-wire
The following link explains how to convert your dryer from 3-wire to 4-wire:
If you have questions, or require further assistance, please let me know. I hope this helps you.
Jan 11, 2009 | Whirlpool LER5636P Electric Dryer
Correctyly wiring power supply to Kenmore dryer
A three wire pigtail is connected thusly. The two outer wires go to the two outer terminals on the dryer, the center lead goes to the center of the dryer terminal block. If its a four wire pigtail, the outer leads go to the two outer terminals on the dryer, the white goes to the center terminal. The jumper strap on the center is removed and the green goes to chassis ground.
Sep 16, 2007 | Maytag Neptune MDE7500AY Electric Dryer
Dryers Logo
613 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
