Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Interior oven light won't shut off.
Normally, light goes on when door is opened and shuts off when door is closed. Removed door of my Frigidaire oven to clean in between glass and now interoior light will not shut off when door is closed. HELP!!!
  • Daniel
    Daniel Dec 29, 2013
    I'm having a problem with my oven that is similar. My oven light does not go on when I open the door as it used to. Any ideas as to the problem? The light works when you turn it on manually. But not when you open the door.
  • 6,784 Answers
Hi, i would check the pressure switch and its connection as well. either the switch is malfunctioning or the wires and connectors are corroded. simply replacing the wires or switch will fix this issue. the switch is usually located on the rim of the inside of the oven door. it will make contact with the oven door and as the oven door closes, the pressure switch is depressed inwards, thus, opening the circuit and cutting power to the light.
Please rate and god bless:)
Posted on Apr 16, 2009
Door lock is stuck closed cannot shut door?
Good Morning Richard, thank you for your inquiry!
Based off the information you have provided your Frigidaire oven door is stuck closed and you are unable to shut the door. You can disconnect power from your range for at least ten minutes and that will reset your oven. This may trick your door latch into opening.
You can also hold down the cancel or clear button for 10 to 15 seconds that may allow your door latch to release. Also attempt to hold down the light and cancel buttons. I hope this information has been helpful to some degree. -Matt
Mar 23, 2015 | Frigidaire Ovens
Our electric convection oven heats up and when you open the door and close again it no longer heats, fan stays on and the light goes on when door open and off when door is closed, any ideas?? Thanks
Hi, You can look at the micro switch on the oven door, sounds like it might have been installed on a normally open auxiliary rather than a normally closed aux. hope this helps
Oct 09, 2014 | Ovens
I have a frigidaire mef352bgwd electric oven- after a power outage the lock engaged (door open) and now blinks continually. Tried shutting off breaker for 30 minutes- no change.
There is a pin that tells the oven the door is open, you need to push it in an hold it. It is pretty stiff, you can't use your bear hand. It will be in the upper left of where the door closes.
Jan 07, 2010 | Frigidaire GLEB27S7A Electric Single Oven
My oven door will not shut all the way. It
It is probably the self-cleaning latch that keeps the door from being opened during the self-cleaning cycle. Looks like it didn't retract all the way. Did you use the self-cleaning cycle? . Do this: Quiet the house down, open the door slightly and close it, letting it hit the obstruction. Do this again and again. You don't have to close it hard at all; in fact, do it gently. By listening, you will be able to hone in what is keeping it opened. Then go from there.
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Sharp MW won't shut off
Sounds like it needs a new electronic board or PCB. Although I would consider a new microwave as your microwave is getting on in age and can be a danger to health or dangerous if something blows up.
Jun 14, 2009 | Ovens
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
2,065 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
