Question about Sharp MX-3501N All-In-One Printer
I am trying to set up my Sharp MX-350IN to send faxes to an email address to save on paper. How would I go about doing this?
  • Bryan Luther May 11, 2010
    Is your scan to email already set up and working? If not you have to go to the webpage and set up the smtp server first and then go to the applications section of the website and set up inbound routing. have you contacted your dealer?
    Sniper:
  • 54 Answers
Posted on Apr 19, 2009
Tip
SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)Posted by...
<a href="http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/">SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)</a> <span>Posted by <a href="http://www.smtp2go.com/blog/author/admin/">mi6</a> on </span>August 19, 2009 - 4:06 am <span>Filed under <a href="http://www.smtp2go.com/blog/category/uncategorized/">Uncategorized</a></span> Some Sharp fax machines require a certain type of SMTP server in order to be able to send emails. SMTP2Go provides an SMTP server that authenticates senders based on their 'from' email address, meaning that it works with fax machines that are unable to send an SMTP username or password.<br /> Two examples of SMTP setup procedures for popular Sharp fax machines are below:<br /> Sharp UX-B800SE and UX-D1200SE Broadband Fax SMTP setup In the 'Network Settings' area, enter smtp2go.com as the SMTP server, and <b>UNCHECK</b> the box 'POP before SMTP'. Try entering either port 2525, 25, or 587 as the outgoing SMTP port. Then, make sure you are sending 'from' an email address that is registered with SMTP2Go.<br /> See a sample screenshot from the UX-B800SE fax below (click on it to enlarge):<br /> <br /> <p><a href="http://www.smtp2go.com/blog/wp-content/uploads/2009/08/sharp_fax_ux-b800se_smtp_setup.gif"><img src="sharp_fax_ux-b800se_smtp_setup_small.jpg" /></a><br /> Please note that Gmail's SMTP server doesn't work, as it not only requires a username/password, but it also requires that SSL/TLS is used.<br /> Please note: some fax machines may still have a problem sending - if this is the case, use the IP address of 207.58.142.213 instead of smtp2go.com as the SMTP server.<br /> SHARETHIS.addEntry({ title: "SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)", url: "http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/" }); <span><a><span>ShareThis</span></a></span><br />
on Feb 15, 2011 | Office Equipment & Supplies
Sending a fax
You are doing it in the wrong order.
Press FAX. Load your document/s. Dial the number and press black start. It will take up to ten pages automatically That's it.
Jan 29, 2014 | Sharp MX-2600/MX-3100N Black Toner...
Sharp Operation Manual
The simplest way to do this is through the web page of the machine.
enter the ip address of your machine into a web browser's address bar
If you dont know the IP address you can print it out, instructions below:
http://equipmybiz.com/blog/Entries/2014/1/15_Print_a_NIC_Page_with_Network_Info.html
Then on the web page, click:
System Settings
Image Send Settings
The default password for login is admin
Then on the front image send page there is a section that says Transmission report select settings - put it on All Report and click submit.
Apr 23, 2013 | Sharp Mx-2610n Color Copier, Printer,...
Sharp manual for a UX-510 fax machine I need the manual to set the machine its a fax machine by sharp
I possess this manual and will be more than happy to email it to you. Send an email to LBrown18062@hotmail.com Please put SHARP UX510 as the subject and I will get it out to you. Lawrence
Oct 11, 2011 | Sharp UX 510 Plain Paper Thermal transfer...
Do I use ink jet paper or laser paper in my Sharp MX-350IN copier?
Laser paper. You really can use a broad range of paper.And papers up to 120lb. Any paper heavier than standard stock (20lb) must be designated as heavy paper in the bypass tray and run in the bypass tray. Bypass tray is the fold down tray on the right side of copier
Apr 05, 2010 | Sharp MX-3501N All-In-One Printer
Sharp MX-2300N trying to send image to email address gives error
The new fire wall was set up with a password, free the password on the server setup, that should eliminate block.
Nov 21, 2008 | Sharp MX-2300N Color Copier
Sharp MX-4501N Mac drivers 1.1 will not hold black and white colour setting in printing profile (save as)
You are using Bonjour to print to the MX-4501N which uses a generic post script driver. To fix this, you must install the printer using the proper driver from Sharp. For a first time install, download the drivers, install the drivers, restart, and install the printer as an IP printer, specify the IP address, it should be using the LDP (Line Direct Printing) protocol, and specify any additional optonal accessories you have on your MX-4501N. Hope this helps :)
Oct 09, 2008 | Sharp Office Equipment & Supplies
Email
Verify that that the email address is valid by sending an email to them from a computer.
Sep 09, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
Email address
Press function 62 and print out the one touch list and make sure the address is typed correctly.
Sharp MX-3501N All-In-One Printer Logo
1,167 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
