Question about Linksys Wireless-G Broadband Router
Router We have a 2.4 GHz router.We had to turn off the power in the house. When it came back up the router now has a orange light that says Cisco systems. We have the internet on our main computer but the router is not working
  • 71 Answers
On the back of the router there is a little hole with a button inside of it. It is a reset button. Hold it in for about 10 seconds, this should reset the router to factory defaults.You will have to re-input all of your settings but I think it should fix your problem. If you have a version 1, 2, 3, or 4 of that model, then you can turn it into a super router by installing a 3rd party firmware like from here - http://www.dd-wrt.com/dd-wrtv2/index.php - if you areintersted, please leave a comment and I will tell you how to do that. Hope this helps you.
Posted on Sep 16, 2007
SOURCE:
Linsys ea6500 blinking
If the Power or Diag LED (Light Emitting Diode) on your Linksys router is blinking, it means the firmware is corrupted. If this happens, you won't be able to do the following:
• Access the router's web-based setup page
• Assign IP addresses to computers connected to your router using its DHCP capabilities
NOTE: This also applies if your router's LED is dimly illuminated.
Listed below are the things that you can do to solve this issue:
Powercycle the router
Assign a static IP address to your computer
Ping the router
Reset the router
Update/Re-flash the firmware using the TFTP utility
Jun 27, 2014 | Linksys EA6500 Dual Band AC Gigabit...
Orange light on the router
The color orange indicates that
the Router is not using the SecureEasySetup
feature, while the color white indicates that the
Router is using the SecureEasySetup feature.
When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and
start flashing. After the Router has generated
the SSID and WPA Shared Key, the Cisco
logo will stop flashing and stay white.
So this "feature" can be turned off (meaning the light is off)
On the web-based router setup (192.168.1.1 in web browser) go to Wireless > Advanced Wireless Settings
Secure Easy Setup
This feature allows you to enable or
disable the SecureEasySetup feature. Select Disable to
disable the feature and turn off the button's light. The
feature is enabled by default.
Click the Save Settings button to apply your changes, or
click the Cancel Changes button to cancel your changes.
Dec 11, 2012 | Linksys WRT320N Wireless Router
The internet connection in my area went down yesterday, but i didn't know this and thought the reason i couldn't access internet was a problem with my linksys wrt54g router. So i unplugged and...
The first thing you should do is a proper 'powercycle' for all of your internet equipment.
To do this:
1) Unplug the power to your modem and your router, and power off your computer.
2) Wait a full minute.
3) Plug the power back in to JUST the modem.
4) Wait some more - for the modem to fully connect to your ISP, and the lights to indicate. If you're not sure, just wait about 2-3 minutes.
5) Plug the power back into the router.
6) Wait another minute or two for the router to finish connecting.
7) Then turn the computer back on.
You can bypass the computer turning on and off if you can repair your wireless connection.
If this doesn't work, there is a pinhole sized reset button on the router itself that you will need a toothpick or somesuch to press - press and hold the button for 5 seconds, and then try the steps above again. If you do this, the network id and password will be reset to the default, just like it was when you bought it.
Jul 20, 2011 | Linksys Wireless-G WRT54G Router
I have the WRT54G wireless-g router and I tried to switch it on (after I had switched it off because I was overseas). However instead of the yellow light to come on (over cisco systems logo), a white color...
Does the Cisco logo illuminate yellow? Is the power LED white?
In any case locate the reset button on the back. It is just to the left of the
Ethernet cable jack. With the power on, depress this button for 2-3 seconds and release.
All the lights should come on the go through a series of self tests. Once settled down after about
2 mins see if the lights change. If nothing changes, it sounds like it was dropped causing the
colored plastic tabs to jar loose.
Hope this helps.
Nov 29, 2010 | Linksys Wireless-G WRT54G Router
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Cisco 1841 Freezing at System Configuration Dialog
Try resetting its firmware or try booting it in another location.
May 08, 2009 | Cisco (1841) Router (cisco1841)
Router quit working
How about the power light? Is it solid green?
Aug 03, 2008 | Linksys Wireless-G WRT54GS Router...
Wireless router G WRT54 V8 cisco systems light is not on any more
Had the same problem -- hold the reset button (on the back next to the ports) in for 30 seconds while on and then pull the power plug and wait 30 seconds before replugging --- it should completely reset and you will have to redo your settings but you won't have to buy a new router atleast..
Apr 28, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
211 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
