Question about Pro-Fit Pro.Fit Fo 74 92 Ford Bronco/Pickup 92 Up
My shift lever on my 92 bronco made a snap noise,now it wont shift.Just flops around
  • 1,305 Answers
Ok ready to stand on your head under the dash?
It's doable... there is a flange connected to the gearshift lever under the steering column. If you remove the lower dash cover where the fuses are, you should be able to see it when you move the gear shift lever... look around on the floor of the truck to see if you dropped a star-headed bolt or two... these bolts worked loose on my superduty and made shifting very difficult..it was an easy fix... let me know how you do on it.
Posted on May 10, 2009
1988 ford bronco full size 4x4 installed new fly wheel and now it will not shift out of low gear
check that you have installed the gear lever in the shift rail when you refitted the lever tower on top of the box
Nov 07, 2014 | 1988 Ford Bronco
Shift lever
Possibly the lever's locking bolt thread has stripped or the thread on the bolt is worn. Another aspect is the splines in the lever are shot and/or the splines on the gear change shaft are badly worn. Remove lever and check the splines on both shaft and lever also check around the lever fixing section for any cracks. Check the threaded section of the lever with a brand new bolt the bolt should be easy to turn in and out by finger and should have no side to side play. When refitting the existing lever or a new one make sure the lever is a good fit on the gearbox shaft splines before you tighten the bolt.
Mar 29, 2014 | 1997 kawasaki VN 1500 Vulcan Classic
2000 ford focus, manual, the stick stick flops around not engaged
There are three posibilities for this worn linkage on the gearbox the linkage under gear lever or a broken mounting on the bracket where the lever comes up through the floor as long as you can get all gears it will be exturnal linkage fault.
Mar 04, 2014 | 2000 Ford Focus
1983 camaro turn signal switch installation
What I remember is a black plastic part in the side of the switch that the lever snaps into. You may need to get a new switch.
You can look at one in a parts store to see if yours is missing anything.
Aug 23, 2012 | 1983 Chevrolet Camaro
92 chevy 3500 6.5 auto trans trouble
For Automatic transmission problem,click the link below:----Automatic transmission troubleshooting:---- http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html---------Automatic transmission shift lever issues?------- http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
-----------AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
-----------Transmission fault light on car dash? http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
--------Transmission shifting problem? http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
--------Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into reverse? http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
----------Transmission is making buzzing noise? http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
-----------This will help.Thanks.
Feb 22, 2012 | 1992 Chevrolet C/K 3500
My 92 dakota shifts hard from 1st to 2nd gear but does shift to all gears?
For Automatic transmission problem,click the link below:---- Automatic transmission troubleshooting:----
Transmission fluid leaking?
This will help.
Thanks.
Feb 03, 2012 | 1992 Dodge Dakota
After replacing drive belt, [954-0467], my troy bilt bronco won't fully stop, and the transmission control lever is difficult dto shift. When I turn off the ignition brake functions and shift lever...
The new belt is too tight.Look for an adjustment on the control lever or tension pulley.If that wont fix it.Remove the belt and take it to a NAPA.They can make you a new belt just 1/8 inch longer.I have had to do that with an old mower I had.
Thanks for using Fix Ya,I hope this helps.
Jun 03, 2011 | Mtd Drive Belt 42"
The transmission lever has come loose and is locked in park. The motor can be turned on but the lever shift cannot be moved into reverse or drive. The lever flops around freely and moves freely into...
You will need to repair the shift lever or any damage to the associated mechanism. You will need to provide year and model for more specific repair information, or see your local Ford dealer.
Aug 21, 2010 | Ford Lincoln Continental Cars & Trucks
The 4 wheel drive shifter is broken. How does the linkage to the transfer case come apart?
Shift Lever NOTE: Remove the shift ball only if the shift ball, boot or lever (7E067) is being replaced.
Removal
  1. Raise vehicle on hoist and position suitable safety stands under vehicle.
  1. Prior to removing the control lever assembly (7E069), be sure the shifter is in the 2H position.
  1. Loosen (do not remove) the nut retaining the shift handle (7E067) to the control lever assembly (7E069). Remove the shift handle (7E067) from the control lever assembly (7E069).
  1. Remove the vent hose (7D494) from the notch in the detent plate.
  1. Remove the control rod (7A315) from the control lever assembly (7E069). ani_caut.gif CAUTION: When removing the control rod (7A315) off the control lever assembly (7E069), do so very gently so as not to damage the control lever assembly.
  1. Loosen (do not remove) the large pivot bolt holding the control lever assembly (7E069) to the detent plate.
  1. Swing the control lever assembly (7E069) out of the way and remove the two bolts (39129-S2) retaining the detent plate to the transmission extension housing. Remove the entire control lever assembly from the vehicle.
Installation
  1. Prior to installing the control lever assembly, be sure the transfer case link (7B106) is in the 2H position (pointing upward).
  1. Install the two bolts (39129-S2) to retain the control lever assembly (7E069) to the transmission extension housing and tighten to 92-125 Nm (68-92 ft-lb). Refer to the following illustration for bolt hole application.
  1. Attach the control rod (7A315) to the control lever assembly (7E069).
  1. Tighten the large pivot bolt to 92-125 Nm (68-92 ft-lb).
  1. Attach the vent hose (7D494) into the notch in the detent plate so the white mark is flush to the outside surface of the plate.
  1. Install the shift handle (7E067) into the control lever assembly (7E069). Tighten the retaining nut to 27-38 Nm (20-28 ft-lb).
  1. Check transfer case for proper shifting and operation.
Feb 27, 2010 | 1992 Ford F250
Stuck in 4 wheel high lock
I had the same problem just yesterday. My shifter lever for the 4x was just flopping around. I crawled under the driver side right behind the driver front tire and there was a lever hanging down with an "L" shape on the end of it and a groove cut all the way around it. That lever is the end of that shifter lever inside of your vehicle. it attaches to another lever "a flat bar with a hole drilled into it and mounted to the side of the transmission. Don't attempt to move the flat bar but do reposition the lever inside the vehicle so that you can put the "L" shaped lever back into the hole of the flat bar. There is supposed to be what they call an "E" ring on the end of this "L" shaped lever that slips over the shaft in that Groove I was telling about. it snaps into place and holds the two levers together. It's missing so go to auto parts store and get a new one. I'm headed there today. Shift your car into 2wd and drive. Then replace the "E" ring that's missing and you're good to go.
Good luck
Apr 29, 2009 | 2000 Dodge Durango
Pro-Fit Pro.Fit Fo 74 92 Ford Bronco/Pickup 92 Up Logo
102 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
Craig Butler
Craig Butler
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
