It says RW closed. How can I fix it??
Carrier furnace says rw closed. What is this and how can i fix it?
  • 659 Answers
This is the roll out switch located on the burner. Its a small disk with 2 wires and a small button in the middle. Depress this button to reset.
Posted on Apr 17, 2009
My dvd-rw stopped working. when I close door, I hear a noise, the light goes out. nothing happens. Device manager says the drive is working properly.
it may be that the dvd/rw media needs to be the proper type. look at old media you have used in the past and insure the new media is the same. the 2 different types are dvd +rw, dvd+r, dvd-rw, dvd-r. the plus or minus are the fifferences you should pay attention to , unles your device is +or - compatable.
Jan 19, 2011 | HP Compaq Presario SR1330NX (PP161AA) PC...
What file formats does the Sony DVP-NS51P support?
It will play the following: DVD Video VCD SVCD DVD-R DVD-RW DVD+R DVD+RW CD (Audio) CD-R CD-RW Picture CD DVD+R DL DVD-VR as well as MP3 and JPEG file formats. Hope this helps.
Jan 10, 2011 | Sony DVP-NS51P DVD Player
I want to know my puk number
Hello and sorry to read about your problem.
First, their is no secret code to unlock your phone. The carrier has the ability to unlock your phone. But it must be that carriers phone. you need to contact the carrier, that owns your phone. I far as your private security code PUK,
Example: Phone was on AT&T and you want on T-Mobile..
AT&T has to give you the unlock code.
In addition to that, their is another code which allows you to change carriers, again you must contact the carrier...
NO SECRET CODES FOLKS. Their are online service's that you can pay for a PUK code.
Now i tried to help you.Please help me, and rate/vote this response. Thanks
wer
rwe
rw
rw
er
Dec 25, 2010 | Cell Phones
My Drive is not reading any CD I put in it
Optical drive problems
NOTE: High-speed optical drive vibration is normal and may cause noise, which
does not indicate a defect in the drive or the media.
NOTE: Because of different regions worldwide and different disc formats, not all
DVD titles work in all DVD drives.
Problems writing to a CD-RW or DVD+/-RW
CLOSE OTHER PROGRAMS - CD-RW and DVD+/-RW drives must receive a
steady stream of data when writing. If the stream is interrupted, an error
occurs. Try closing all programs before you write to the drive.
refer to the manual , click this link http://support.dell.com/support/edocs/systems/ins1721/en/om_en/pdf/GU051A03MR.pdf
Oct 16, 2010 | Dell Inspiron 1721 Notebook
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
I cannot format DVD-RW
I had to download the latest firmware (rev. VS0M) for Lite-On DVDRW SOHW-832S. This fixed the problem.
Jun 21, 2008 | Roxio Easy Media Creator 7
Dvd-rw
my dvd drive will not close properly
Dec 30, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
Dvd-rw from sony handycam
this is a common problem
sony handycam older versions does not read or support the 8cm rw dvd disks
so sorry
Oct 22, 2007 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
Philips CDD 4801 CD-RW Burner cycles
Is this covered by a front console cover type or is the dvd, as it is with it's own eject button, as it may be touching the front eject button.
Jan 15, 2007 | Philips CDD 4801 CD-RW Burner
Heating & Cooling Logo
365 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
