How many rings does the Sharp UX-300 Fax Machine use before picking up?
I want to use my fax machine on my home phone. Their is a voice recoreder that picks up calls after 4 rings? How do I configure the Sharp to pick up before voice recorder?
    New Friend:
  • 120 Answers
Set the reception mode to answer machine,
Posted on Feb 16, 2008
Sharp parts manual
Wow thats an old fax. Try www.sharpusa.com . They may still have owners manuals listed there.
Jun 30, 2014 | Sharp UX 300 Plain Paper Thermal transfer...
Problem with the F/T setting.
leave these phones unused for one day and then use it and see.
leaving them unused will make everything get settled.
Jul 29, 2008 | Office Equipment & Supplies
Sharp UX-A1000 Fax Machine Document Feeding Trouble
Problem is most likely caused by a worn paper pick roller. It would be more expensive to repair this fax than to just replace it.
Nov 28, 2008 | Sharp UX 108 Roll paper Thermal Fax
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Sharp fax ux b700
you have to select Auto mode of reception for fax machine with the help of receive mode button of fax machine. this setting will set machine for automatic fax reception and you get fax within 2 or 3 rings as set to your machine.
May 05, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Line error
I have a Sharp UX-300. When I get a line error, the easiest way to clear it is to unplug the fax machine from the power outlet and let it stand for at least a minute. Then plug it back in to the power outlet. If this does not clear the problem, use a regular phone to check if the phone line between the fax machine and the wall is 'OK'.
Nov 15, 2007 | Sharp UX 355L Plain Paper Thermal transfer...
Can I use this fax on a telephone line together with a GE 2.4 GHz Cordless Telephone (Model 27992B)? Will it be possible to recive messages and faxes when no one is at home? Remark: The answering machine...
sure u can: Installation with an answering machine and/or extension telephone: 1. Remove the seal covering the TEL. SET jack on the rear of the fax. Connect an extension telephone or answering machine to the TEL. SET jack. 2. If desired, connect an extension phone to the answering machine. from the user Fax guide: If desired,you can also connect an answering machine or an extension telephone to your fax. ¨ Connecting an answering machine to the fax will allow you to receive both voice and fax messages on the same line while you are out. For details on using this feature, see Chapter 7. (Note: Do not connect an answering machine to your fax if you will be using the distinctive ring feature described in Chapter 2.) ¨ You can connect an extension phone to the fax to make and receive calls like any other extension phone on your line.
Oct 09, 2005 | Sharp UX 510 Plain Paper Thermal transfer...
116 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
