Question about Kitchen Ranges
I keep getting a F-30 code
Kenmore 47833, I keep getting F-30 code
    President:
  • 1,865 Answers
I need a model number
Posted on Apr 16, 2009
Receiving a F 10 message
F10 error code means "runaway temperature condition"
If your oven is overheating, unplug the power cord for a few minutes. When plugged back in if the oven is still overheating, you will need to have the temp sensor and control checked.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven. Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven. Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms. The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website.
Hope this helps.
Apr 25, 2011 | Kenmore 47833 Electric Single Oven
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Oasis Elite HE washer. I keep
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 11, 2009 | Kenmore Washing Machines
Electric panel on stove displays
check the sears kenmore site they have info on error codes.
Aug 22, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
My Kenmore Elite Smartwash control locked light went on after I finished a load. Now no buttons work. How do I unlock the controls?
Just remember, the instructions are printed near the button. This features locks and unlocks the control panel as a designed safety feature to prevent small children from manipulating the controls. In addition, if you get error codes, or the panel starts flashing or freezes up, sometimes these errors can be erroneous. Unplugging the unit for 30 minutes will reset the Central Control Unit (CCU). This is the main "brain" of the washer. Any error code following a computer reset, is usually a genuine problem. If you ever have questions about this washer in the future, please keep me in mind. Congrats on getting it working again!
Mar 03, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite H3 error code F11
F11 is a serial communication error. It is recomended to check connections from the motor control unit to the ccu. We are looking for the blue wires that carry info from component to component. The ccu is on top under the cover positioned in back for older machines and front right for new machines. The mcu, motor control unit is behind the kick panel below the door and is front left usually.Again we want to unplug check for dark or crusty connections if not to carefully reseat the connection and not only the blue serial wires but power as well. Remember to first unplug the machine and while you work the machine can reset, 30 minutes is typical.
Sep 08, 2008 | Kenmore Elite 45986 Front Load Washer
Can't turn off my Kenmore 47833
check to see if the connections are good on the back of the control board and if they are good then you need to replace the control board (clock) assembly let me know how you make out
Sep 01, 2007 | Kenmore 47834 / 47832 / 47839 Electric...
Kenmore oven
I noticed your question and I just experienced the same problem. Curious if you found the solution or not, since no one has posted one?
Feb 15, 2007 | Kenmore 47833 Electric Single Oven
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
