Question about Canon MV850i Mini DV Digital Camcorder
Can't open the dv tape
First camera shows "REVOVETHE TAP". after can not open the dv tape
    Sergeant:
  • 274 Answers
Solutions * The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. * Once the power source is available, some models require manually unlatching and opening a cover. * When the cover is fully open, the cassette will eject automatically after a few seconds. * If the tape still will not eject, seek assistance from a Service Facility because you need a special tool to remove the tape without causing further damage.
Posted on Sep 16, 2007
  • Anonymous Sep 18, 2007
    If you have sufficient power and it still does not open, by forcibly removing the tape you can damage the tape carrier and then you have even a bigger problem.
    Sorry, but you need to take to a repair shop that has the necessary tools to help you.
SOURCE:
Hi. put in a mini-dv tape recorded on a sony z1 camera, the sony dsr-45p tape deck doesn't show any footage from the tape despite the camera had playback to show that footage was recorded. Using a windows...
Try to playback with other tape recorded earlier from other camera or VTR .If other tapes are palying properly without any glitches then it might be the problem with this recording.
anand
Oct 22, 2010 | Sony DSR-45 Mini DV VCR
the issue is probably related to the format the tape was recorded in. a z1u records in hi def (hdv) the dsr 45 is standard def ntsc. not compatable, play the tape in a z1 to recover
I was getting a message clean heads, so I bought the cleaning mini DV to insert. I pressed the button to open the door where the mini DV tape is and it popped up, but will not pop open to release the...
It sounds like something has jammed the tape door mechanism preventing it from opening. This is a very delicate part of a mini DV camcorder. I would highly recommend taking it to a electronics repair shop where it can be checked out. If you try and force the tape out you will probably cause considerable damage to the tape transport system making your camcorder unusable.
Take Care,
Aug 09, 2010 | Canon Optura 50 Mini DV Digital Camcorder
No DV output from Canon GL2. Using a firewire cable from DV port on camera to firewire port on Mac Pro tower. Attempting to import the camera live to Final Cut Pro. Previously worked just fine.
Was the tape your trying to import recorded on the camera you are trying to import from? I've noticed that sometimes the tape I recorded on my old Panasonic won't show up on my GL2. It's like it's a blank tape, but I know it's not, as I have it labeled. Stick it back into the panasonic and it plays fine.
Nov 12, 2009 | Canon GL2 Mini DV Digital Camcorder
Where do you tap on the camera?
Close the LCD screen and whack it with an open palm
Jul 19, 2009 | Canon ZR100 Mini DV Digital Camcorder
I can record and see it recording but i can not view my recording. At first the tape wouldnt eject but i was online and i went to troubleshoot for the cannon mini dv camcorder zr200 and it told me to tap...
1. Connect the camcorder to a TV and check if you can playsee the tape.
2. Take that tape and check it using another miniDV camcorder.
this way you will know if the issue is within the camcorder or the tape.
If is within the camcorder .. take it to a service dealer and see how much is to fix it. Chances are that is not worth to be fix. A brand new ZR900 is just 200 USD ...
Dec 23, 2008 | Canon ZR200 Mini DV Digital Camcorder
Mini DV tapes transfer to computer
wow, i have the same exact problem. im using a canon too. and i dont have an installation CD or anything, because i baught my camera at a pawn shop. the only thing i can think of is that i might be using the wrong type of fire wire cord? do i need to use a DV fire wire cord? i have no clue.
Aug 20, 2008 | Canon MV730i Mini DV Digital Camcorder
Blue Horizontal Lines
if you dont have time to get it fixed, tap on the side where the tape goes in. I had to tap it a couple of times before everything started work fine again.
May 06, 2008 | Panasonic Palmcorder PV-GS15 Mini DV...
C-31:21 code eror
C:31:21Winding S reel fault when counting the rest of tape. Load the tape again, and perform operations from the beginning
The tape may be faulty
Oct 26, 2007 | Sony Handycam DCR-PC101E Mini DV Digital...
Trouble working sony dcr-trv6 mini dv digital camcorder
( c : cassette : 30 capstan fg ) ; your capstan motor is stalling - try ( other brand ) new tapes and gently ! swaying camera from side while loading - if loads , your tape mechanism is dirty or is going out of alignment ; - - if the camera will not unload tape ? the capstan motor may be failing ( connector is loose , corroded ) or - it is jammed and it needs . . . disassembly . . . to complete checking .
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Canon MV850i Mini DV Digital Camcorder Logo
134 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
