Question about HP Officejet 5610 All-In-One InkJet Printer
Faxing something Does the printed side of the document face up or down on the glass when faxing? When faxing I'm not sure whether or not to face the document print side up into the feeder of print side down into the feeder? Please Help!
Khalsa007
  • 79 Answers
SOURCE: WON'T SEND FAX FROM FEEDER.
u can try the following steps >
unplug the power cord from the back of the unit [without turning off the unit ] > press and hold ok and cancel key together > while holding these keys down plug in the power cord back into the unit . do not release the keys > wait for a few seconds it will make certain noises an wud turn off automatically .
turn on the printer again it will go into allignment phase > let it finish.
after its done > try to make a copy from the feeder .
Note - In case [ok and cancel key ] combination doesnot work < u can try # and 6 key combo as well with the same procedure.
THANKS
Mac
Posted on May 27, 2008
hashir4u
  • 79 Answers
SOURCE: faxing something
Hi
In the document feeder text should face up and from the scanning glass it should face down.
SOURCE: I want to copy something from the glass and not
were you able to figure this out? I'm having the same problem!
Posted on Feb 24, 2010
  • 3 Answers
SOURCE: Original Loaded
I just came across this very same problem today on my L7580 and I found that there is a spring loaded bar that flips down and makes a contact. When paper is inserted it lifts this bar up and tell the feeder that there is a document. If this is stuck in the upright position then you will always have the "original loaded" message and have your issue. Mine had popped out of its alignment holes and I had to snap it in and the whole thing worked like a charm!!! I hope this helps everyone else with this issue!!!
Jason Gray
Posted on May 13, 2010
mcavinee
  • 236 Answers
SOURCE: Paper does not feed from top of my hp 7210 printer
The rollers on the feeder can go bad and the best way to solve it is to get a new complete assembly. Check the website under your make and model for the assembly. YOu might also want to check for paper jam
Posted on Mar 19, 2011
When faxing should the paper be face up or face down?
According to the manual, the documents should be placed face down in the auto document feeder.
Here's a link to the manual that I spoke about:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_490CW_EN_1773.PDF
Hope this helps!
Jun 21, 2011 | Brother MFC 490cw Color Inkjet...
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
Does canon pixma mx 310 work faxing page up or page down?
When using the ADF load the document with the side you want to copy, fax or scan facing UP in the ADF.
When using the platen glass load the document with the side to be copied, faxed or scanned facing DOWN on the platen glass.
Trust this helpful.
Please vote.
Dec 15, 2010 | Canon PIXMA MX310 All-In-One Printer
When sending a fax, do i face the front side of my document face down or the back side down?
If you are faxing using the feeder , the front page will face up. and if it is on glass/scanner will be faced down.
Thanks for joining us, for more assistance please stay connected with Fixya.
Have a nice day.
Mar 08, 2010 | HP LaserJet 3330 All-In-One Printer
Should print be facing down on machine or up?
Generally face DOWN. depends on how image is scanned though. If it goes in vertical usually image is towards you, Flat scanners, face down on glass.
Feb 01, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Where do you load the sheet you want to fax
Lift the lid. Place document with printed face down on glass with top of document to the left of the machine, with top corner to the farthest left corner of the glass. Press "Fax".
Nov 28, 2009 | Canon MX300 Office All-In-One Printer
Whitch way does the paper go in for faxing ?
If your using the feeder on the top of the scanner, it should go face up. If you are faxing from the glass - face down.
Oct 29, 2009 | HP Officejet 6500 Wireless All-in-One...
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Which way does the paper go into the feed when faxing?
Load the originals, with the print side up, into the document feeder tray. If you are sending a single-page fax, such as a photograph, you can also load the original on the glass. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 02, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
78 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
