Question about Genie Company GV150 Wet/Dry Vacuum
HOW DO I SWITCH MY GENIE PB/15 BLOWER/VAC TO SUCTION?
I just asked a question a couple fo hours ago about the little paper liner inside, asked if I was supposed to remove the liner for wetsuction, but now I can't figure out how to get the Vac out of blower mode and into suction mode!
There's no switch to flip, as far as I can see, but there are two 'holes', a top one on the actual blower apparatus (which attaches to the top of the yellow 'drum' ) and a lower one that the hose fits neatly into. Maybe this has something to do with it?
SOURCE: HOOVER STEAM VAC SPIN SCRUB
Check the flexible hose that comes down from the handle.  Look for a crack where it plugs into the base unit.  (visible once you open the handle up and remove the cleanable catch basket)
Posted on Oct 22, 2007
galati2k
  • 281 Answers
SOURCE: Wont suction the water
the suction channel is probably clogged.the suction channel goes right up the middle ,you can see it by looking through the cover.probably a lot of hair and dirt stuck up inside.there are some screws on the botton you need to take out then the cover will come off.seperate the 2 pieces of plastic and you will be able to clean the channel.please leave feedback
Posted on May 01, 2009
SOURCE: USE GENIE WET DRY VAC WITH OR WITHOUT PAPER LINER?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The PB15 uses a fairly large pleaded paper filter for dry use, but it is an odd ball, as most of these type filters are held in place bay some sort of plate, and plastic nut. The PB15 uses a filter that has a bottom, and is pressed into place. For wet use, I would see if you can use the foam filter for one of the Craftsman small W/D vacs, like the old 2 gallon model, held in place with a rubber band, which is slipped over the cage with the float ball. It needs to be sealed across the bottom. That should cut down on spray making its way to the motor. The PB15 does have one good feature as the vacuum inlet has an elbow which keeps the water from being sucked straight into the motor intake, so the foam filter should do the job pretty well. I’d also look at the bag and rubber band that is used on some of the smaller Craftsman vacs, which sounds like what has been done on yours already. They are easy to find.
Because Genie no longer makes any vacuums or blowers, and did not keep a parts inventory to support owners of their products (a reason not to buy one of their garage door openers) it might be best in the long run to ‘garage sale’ the Genie, and buy a new vac from a brand that will be around for awhile. I have two Craftsmen, and one Ridgid, besides the PB15, which is going in the nest garage sale, for the above reason.
As far as your blower to vacuum problem -- The hose is moved from the blower outlet, which is the top black piece with the handle and switch, to the hole in the canister for vacuum. The intent of the PB15 was to use the top piece as a hand held electric leaf blower, or when attached to the yellow canister as a vacuum, when you use the hose attached to the canister.
Posted on May 06, 2009
  • 15 Answers
SOURCE: loss of suction
Make sure the recovery tank lid is on correctly. Also make sure the float on the receovery tank lid is down.
Posted on May 25, 2009
  • 5 Answers
SOURCE: dyson 18 losing suction
Check the HEPA filter if it has one. This bit of foam gets clogged over time and significantly reduces the suction especially if you've been vacuuming a lot of very dusty areas i.e. dust from building work etc. Just wash the filter with lots of water and leave to dry before reinserting.
Posted on Aug 12, 2009
Replacement motor bearings for a genie shop vac/blower model# pb 15
Unfortunately those machines do not have serviceable bearings. The entire motor needs replaced. However, I have saved noisy bearings by putting oil on them, specifically 3 in 1 Blue Label motor oil. A few drops spread on the top and bottom of the bearings and giving the motor a few backward and forwards turns by hand will help those bearings immensely.
Feb 20, 2016 | Genie Company Vacuums
Have a Genie 1.25 HP wet dry vac; can't find filter's.
Used a roll of toilet paper that what I used when I was drag racing. I am sorry that junky, sorry. Contact you local vacuum cleaner repair shop and see if they one on hand. Go to the Internet and for Genie Vacuum Cleaner web side. I'll bet you they will have it, order more than one. GB...stewbison
Aug 21, 2011 | Genie Company Vacuums
My Dyson animal seems to have an electrical issue that I am unable to pinpoint. Neither the wand nor the floor vac have any suction AT ALL. In fact the vac makes absolutely no sound and you wouldn't even...
there is a filter inside the canister, and by your description it sounds like it needs to be cleaned. if you remove the filter and blow it out using a air compressor or using a slightly ridged brush and tapping the filter out this should solve your suction issue.
c...
Jan 02, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Using my wet/dry vac - less than 5 hours on the thing - it just stopped - can't get it to switch back on. Tried different plugs - different days. Although I purchased over 2 years ago, it has hardly been...
It may have gotten hot if you went too long before cleaning the filter. It sounds like you may have burnt it up. I hope not! You might also check to see if you tripped a breaker on the electrical panel. Try plugging it in an outlet that is not on the same circuit. If it works in another outlet, then you have just tripped a breaker.
Good Luck!
Jim
Sep 30, 2010 | Genie Company GV150 Wet/Dry Vacuum
Genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Mar 11, 2010 | Genie Company GV150 Wet/Dry Vacuum
Jhe4576. I own a Genie SV125Q, 5 gallon wet/dry
Where did you buy this unit from? Go back there and ask if they have filters for yours. Otherwise look in the Yellow Pages for vacume cleaner repair shops. Sometimes they have all kinds of filters for all kinds of vacumes. You can try places like Wal Mart. What you want to look for are filters that will work with your unit. The foam filter you refer to is called a pre-filter. It traps the bigger particles so they won't damage your paper filter or clog it up especially if it's wet stuff you're picking up. You can remove that foam filter and gently wash it out in the sink with a mild dishwashing liquid and warm water. And even sometimes if you have time you can wash a paper filter out by hosing it out from the inside, with just a gently rinsing on the outside. Don't use any solvents on it just soap and water. And don't use high pressure either, as it will destroy the paper. I have cleaned my paper filters several times before I finally had to replace them. You can also look at places like Lowe's. They carry shop vacs and a whole assortment of attachments as well.
Mar 07, 2010 | Vacuums
Seems to have proper suction but dirt is not reaching the bag? I have checked all the hoses and there is no blockage.
There may be a blockage on the inside of the vac. I have had this happen to me a couple of times. The first thing I try to do is to make sure the beater brush is turning. If it isn't turning the dirt will not go into the bag. The other thing to do is to take a shop vac or something similar with high suction and see if you can suction out your hose. There may be something so high up in it that you can't see it. The last thing I would try is to take apart the inside where the hose connects to the bag and make sure that nothing is up in there. Try the shop vac first....this has always worked for me.
Good luck.
Aug 06, 2009 | Vacuums
Apr 16, 2009 | Genie Company GV150 Wet/Dry Vacuum
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Old red and black Genie Shop Vac
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=659916
Posted by girl power on Jun 10, 2008
A Wheel or disk has come off of the motor. I would like to get a copy of the user manual to see if I can determine where it came off of. This Genie Shop Vac was given to us from my father-in-law.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can always check with the manufacturer Shop Vac to get an owner’s manual for the older Genie Shop Vac would be @ the Shop Vac Website and or Customer Service of which I will give you @ the bottom of the response. Other wise check with your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Genie Company GV150 Wet/Dry Vacuum Logo
320 people viewed this question
Top Genie Company Vacuums Experts
Michael Vincent Cruz
richie46
Are you a Genie Company Vacuum Expert? Answer questions, earn points and help others
