Question about Philips HTS3440/37 System
Volume problem with surround sound
Problem with volume. Even when we have the volume as high as it can go it is barely audiable.
  • Anonymous Oct 10, 2008
    I have the same problem.. I suspect it may be software related. I have
    tried the reset to default from the Setup menu, but it doesn't reset
    everything, as my radio stations are still there. Does anyone know the
    code to reset it to the as-delivered condition?
I tore mine apart, and the problem seems to be with the power supply in the sub-woofer-instead of 36 Volts, it it producing 2.6V. I'm having a friend have a look at the supply.
Posted on Oct 26, 2008
SOURCE:
No sound from receiver
is the test tone loud or at the same level. you need to check the volume level of your player dvd, cd to make sure it's all the way up some players have volume level built into them.
Apr 12, 2014 | Audio Players & Recorders
I HAVE A SONY KDL-V40XBR1 AND THE SOUND DOES NOT GET VERY LOUD. IT IS GOOD SOUND BUT NO MATTER HOW LOUD YOU PUT IT IT IS ONLY AVERAGE. EVEN GOING THROUGH THE SURROUND SOUND, SO I'M THINKING IT HAS
Your TV has 2 settings that could potentially affect this volume. One, verify the Audio Out option is set to Fixed. This allows your surround to control the volume. Two, make sure Volume Offset for each input could be set low, verify that isn't the case. Hope this helps.
Dec 15, 2017 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
My volume is not working correctly. I have it turned up to 100 - the highest and I can barely hear it.
Monitor volume is affected by TWO volume controls (or even three...)
1: Volume on the monitor can be set to 80%
2: Main Volume on the COMPUTER can be set to your liking.
3: Wave volume on the computer mixer settings should be set for 80% (See Sound on your control panel or right click your volume control near the clock)
If all these are right and the volume is still low, check that the audio is not set for surround 5 or 7 channel and the monitor audio connector is plugged into the REAR green connection on the computer.
Still problems, the audio driver in the monitor is shot.
Dec 05, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Can you hook something up to the aquos to get louder volume?
ARE YOU HOOKED UP TO A CABLE BOX? IF SO THERE IS A VOLUME ADJUSTMENT ON THE CABLE BOX TO HELP OUT. IF NOT I'M AFRAID YOUR ONLY SOLUTION IS TO HOOK UP A SURROUND SOUND SYSTEM.
Feb 03, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sound
The DVD player has a separate volume control - make sure the DVD player's remote volume is turned up as well as the TV's.
May 29, 2008 | Philips Magnavox MWD7006 DVD Player
DVD Volume
Could be the audio format for some movies to enhance surround sound, but could also be a mixer problem on the audio portion of the TV input...accordianman
Feb 27, 2008 | Akai LCT2701TD Television
FLM 3232 television low volume
I hooked my tv up and there is no sound coming from the tv. I do not have surround sound just the tv. How do I make it work I need volume please
Oct 15, 2007 | Polaroid FLM-3232 Television
ID volume
press volume on bottom of phone twice
Sep 09, 2007 | Innovage 1604007 Corded Phone
Audio fade
if there is no problem with the surround sound, you have a problem with the volume regulation circuit or with the main amp of this TV set, But to say the least is you have a backup to fix your problem, with the sound system, you said it works fine. this could run ya about 250 to 400 to repair. Good luck.
Mar 29, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Philips HTS3440/37 System Logo
276 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
