Question about HP LaserJet 1020 Printer
STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
MY HP LASERJET 1020 PRINTER IS LEAVING A BLACK STREAK ON THE RIGHT HAND SIDE OF MY PAPER CHANGED THE CARTRIDGE AND CLEANED PRINTER BUT DID NOT HELP
  • Anonymous Mar 27, 2014
    Printer was printing black lines thru print copies, changed toner and print roller assembly. Now when I print it leaves a black line of toner across the toner cartridge. Shortened the spring on the right side of the roller and this corrected the right side but toner up against the roller is leaving a black line on the left hand side of the toner. Cleaned off the black line on the toner, printed and it is fine but I have to pull the toner every time I use it or a black line develops on the left side where the toner and roller are touching if I leave it in there for a couple of hours. Can't get to the left side spring on the roller assembly to cut it down since that is integrated into the whole roller assembly. Any ideas?
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Posted on Apr 17, 2009
HP LaserJet 1020 Printer Black leaving a black line on the left side of paper. What is causing this
Lines down the page can be caused by a few different things. The most common are the toner cartridge having a defect, or the fuser being worn out. The quickest way to figure out which one is to do a "half print" test. You need to start a print job, then open the toner cover when about half the page has been printed. Check and see if the line is on the page. If it is, then the toner cartridge is to blame. If it isn't, then the fuser will be the problem. (not worth replacing the fuser on this unit)
Be careful of the toner on the page with this test...it will not be attached to the paper and will rub off easily.
Hope this was helpful
Jul 26, 2011 | HP LaserJet 1020 Printer
Laserjet 4050 - black streaking on right hand side of page
It is either the toner cartridge or the fuser.
Put paper in the manual feed tray.
Print the Configuration Pages.
When the sheet is half way fed into the printer, open the top cover.
Remove the toner and look at the sheet of paper. If you see the black streak, the toner is bad.
If the sheet looks good, the fuser is bad. Probably a bad roller, which you can see looking at the fuser.
Jan 21, 2011 | HP LaserJet 4050 Printer
Streaks along the edge of the paper Laserjet 1020 Problem always occurs We tried cleaning the rollers
The drum cartridge may need replacement even if the printer isn't telling you to do so. Try printing a "config" page to see how many pages are currently on the cartridge.
Dec 06, 2010 | HP LaserJet 1020 Printer
Laserjet 1320 is printing a streak down the left side of the page. I replaced the fuser and toner. What's next?
Checking the paper path for ink deposits might be the solution. I had a similar problem sometime ago, where the fuser got some scratch damage for unknown reasons and i suppose was causing unfused ink to accumulate after the fuser, leaving streaks on paper.
Oct 23, 2009 | HP LaserJet 1320 Printer
When printing, I see a vertical streak on the printed page, from top to bottom, about 2 1/4 inches from the left side of the paper, and about 1/16 of an inch wide. I can't seem to see what causes this. The...
This is more than likely down to the upper roller in the fuser assembly. It's the heat roller at the back of the printer. The upper roller wears so paper dust and toner stick to the roller which then can get deposited back on to the page.
Oct 15, 2009 | HP LaserJet 1020 Printer
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
Paper Jam HP LaserJet 1020
Papper never realy "jams" the problene is usualy that the paper is late reaching the next paper sensor. What i would sugest is that you clean the paper pickup roller it is usualy in the shape of a D. Clean it with dishwassing soap dont use water just clean soap rub it on with a clean cloth until the roller is dry so use a small amount. This should solve your prbleme.
Apr 23, 2008 | HP LaserJet 1020 Printer
Regarding printing of envelopes.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00602236&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=439428&productBigSeriesOid=14924&spid=439320&pname=HP+LaserJet+1020+Printer&opname=HP+LaserJet+1020+Printer&pname_desc=HP+LaserJet+1020+Printer&st=1&ptype=consumer&stype=pn&qry=printer+doesnt+print+the+first+time&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+1020+Printer&cqry=&uqry=
Oct 20, 2007 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
1,086 people viewed this question
Seeker5211
Seeker5211
