Question about Maytag Neptune MAH5500B Front Load Washer
All cycles have the same spin
Whether I choose heavy, delicate or perm press, it seems the drum spin at the same speed. Didnot always do this. Also, noticed a smoke smell when machine was maybe over loaded. Belt issue??
    Champion:
  • 219 Answers
Id say u have a bad motor
Posted on Apr 17, 2009
Spin cycle is slow
Are you using the correct setting? Some settings only spin slowly (for delicates for example) and other settings spin at various speeds. When the load is off balance it doesn't get up to full speed either.
If it used to work at full speed, is your belt loose and slipping when spinning? Motor could be going at full speed but the drum is not. Is there an unusual or different sound? Possible smell of rubber as it slips?
Aug 19, 2015 | Washing Machines
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Problem with a Lady Kenmore Model 902202
You might as well go ahead and replace the machine, the cost to repair this problem is going to shock you.
Jun 25, 2017 | Kenmore Washing Machines
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
Le keep coming on
dfgf
dSorry to read about your problem, I hope this helps you out.Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG Washing Machines
The drum is not spinning and the machine stops and has LE on display
3 Thumbs - Helpful
3 Thumbs - Helpful
Jan 01, 2011 | LG Washing Machines
What is a le code and how do i fix it thanks cathy
sdfsf
sdfSorry to read about your problem, I hope this helps you out.Is this a new installation?
3 Thumbs - Helpful
3 Thumbs - Helpful
Error code LE
In new installations, this error can sometimes present because of a mis communication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
3 Thumbs - Helpful
3 Thumbs - Helpful
Dec 27, 2010 | LG WM1814CW Front Load Washer
"LE" what's mean?
Thanks for using FixYa - a 4 THUMBS rating is appreciate dof rnaswering your FREE question.
Sep 25, 2010 | Washing Machines
Whirlpool 4213632 wont drain water on perm press or delicate
check manual as this seems to be correct, Often called rinse hold or crease gaurd on many other machines
Feb 11, 2010 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
