Need to find power supply for melard tech scout all-terrain subcompact notebook// the old type 1
  • 298 Answers
You can visit your local brink & mortar type electronics store or Radio Shack. They Usually carry universal types that come with various adapters. Usually the cost for those is $60-$13
Popular Auction sites usually have your specific model for much cheaper.
Posted on Apr 16, 2009
Bizhub pro c500 error sc32-07
Printer control board (PRCB)
Paper exit fan /1 (M61)
Paper exit fan /2 (M62)
Paper exit fan /3 (M63)
Note:
• Since the old type is not
installed with the M61, M62
and M63, be sure to check
to see if the 25 DIPSW is set
as shown below:
Old type: DIPSW 21-0-0
have a tech check this problem
Feb 15, 2015 | Konica Minolta Bizhub Pro C500
I have a 2011 GMC Terrain (1 month old) and the trunk will not open
With a vehicle that new I would not tamper with it
you may void warranty.
go back to the dealer
you payed good money for your car so get good service
Feb 07, 2011 | 2011 GMC Terrain
I just bought the gmrs 1262 ch and it says up to 12 miles... im not even to miles away from the other one and we cant hear each other... we are on the same channel and everything... HELP PLEASE!!!!
Assuming you have purchased a "bubblepack" type radio, you have a have joined many being mislead about the claims of distance on these type radios. Typically FRS/GMRS Radios claim the have 10, 12, or even 15 mile range. In the fine print however, you will see that it is dependant on conditions such as terrain, buildings, weather conditions and so forth. Most of these high distance ranges can be obtainable with no objects or terrain interfering with a direct path from one radio to another. The transmit power on these radios are also limited to 1/2 watt to 1 watt. Not a lot of power to get very far with less than ideal conditions.
A radio with at least 5 watts output may be more ideal depending on the intended use.
Dec 10, 2010 | Radio Communications
IW-P250A3-1 Resistor R60 is blown. What is the value?
NO Electrical power? Them Power Supplies sometimes goes out at the craziest times. Normally if a powersupply is faulty, you just replace it, with another one . The problem comes in, when you need a speciality type of powersupply instead of your good ole stand by ATX form factor. It appears to me, you have a faulty 250 Watt power supply that is design for that system. You say it's IW-P250A3 Power Supply and you want to know the cost of the part replacement? I seen for prices like $30.00 dollars of as high as $117.00 dollars. I would check with your local Tech Store, or check out ebay, also maybe a tech site like directron or newegg for pricing. Good luck on your adventure with replacing the PSU. Hope this help.
Aug 17, 2010 | In Win PowerMan (IW-P2400L1-0)...
How can I check the battry and the power supply on my Toshiba Satellite A10 PC Notebook. The battry semms dead. When I press the power switch, nothing happens, even if the power supply is connected. When...
The easy way is to take the charger to a shop and have it checked. This requires a voltmeter. If it is bad then replace it. If it is good then the connector where the charger plugs in is probably bad. Unless you are mechanically inclined take it to a shop. I charge $30 to $50 for this type of repair.
Apr 29, 2010 | Toshiba Satellite Pro A10 Notebook
Why is the red light on when connected to the mains? Also the battery doesn't seem to be charging. The pc is only 6months old and used once or twice a week?
1. your battery may need replacement
2. your power supply may need replacement
3. The connection power jack may be damaged and not receiving contact with the power supply.
4. the longevity of a laptop battery can be from 1-3 years max depending on usage.
5. check the power supply adapter with a volt meter to see if it is giving proper voltage.
Mar 13, 2010 | Samsung NC10-14GW Notebook
Green light is on on the adapter, but doesnt charge battery
1. the adapter may be ok but the unit battery that the adapter is charging may have a bad cell and not taking the charge or the power connector may need replacement .
Only a qualified tech can determine this by doing electrical checks with a meter and or diagnostic instrument.
Take your unit to a tech to do a diagnostic.
More than likely it is the battery.
Jan 29, 2010 | ASUS AC Adapter- Universal Notebook AC...
2 year old turned tv on/off several times - TV doesn't turn on
The main power supply is in the protect mode. Usually this is caused by the high voltage section, scan amplifiers, and or the main power supply failing. Many times, when there are failures in the scan amplifier output sections, the main power supply can also be damaged.
On rare occastions, the CRT electron-gun can have a short, and cause this type of failure condition.
An experienced TV tech should be able to service this for you.
Jerry G.
May 25, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
