Question about Symphonic ST420FF 20" TV
Hook up karaoke machine to WF20L6
Hey, do you guys know how to do this? I can't get it to work like it does on my other tvs. I've plugged it into the yellow jack and tried setting the tv to Video 1 or Video 2 - but no luck. Is there a "games" setting for the tv? Thanks JustJude
  • 979 Answers
Try "line in"....accordianman
Posted on Oct 20, 2007
NES help
This is possible a problem with your A/V cords. Try "jiggling" them around when you have the NES turned on, and if there is no picture or sound after that, you may need a new set of the cables.
Jun 19, 2013 | Nintendo NES Console
No Audio When Importing from Canon ZR960
Do you have the leads plugged in correctly ?
Jul 04, 2017 | Canon ZR960 Mini DV Camcorder
Connecting dvd player to tv
the back of dvd is easy because it only has outputs with color code, the inputs and outputs on the back of the tv are grouped if you look closely on the back. select video 1 as an input on tv, and start with the far left yellow jacks on the back of tv, connect yellow rca cable and check for pic on tv, if not move to next yellow jack on back of tv, until you get a pic, connect the red and white right below the yellow jack that gave you the picture and you should also have sound
Mar 03, 2013 | Konka Televison & Video
I got a wii and tried to hook it up to my toshiba tv and when i turned on my wii it was black and white and im positive i have it set up correct or if its just the cords itself the colors are blue green...
Make sure the plugs EXACTLY match the jacks on the TV. If you plug just the green cord into the TVs yellow jack, you will get black and white. If your tv has a combo jack (uses the green of a component input, make sure that the tv is on the right input (COMPONENT and not VIDEO).
let me know.
Jul 04, 2011 | Nintendo Wii Console
I cant connect my wii to my tv. can you give me instructions how?
Most TVs have a yellow video and a white audio and red audio input. The Wii comes with a cable to connect to a TV with a yellow, white and red RCA cable. Plug in the large block end of this cable to the Wii (rectangle block) and the other end into the TV using the yellow plug to the yellow input jack and the white plug to the white input jack and red to red. Select on the TV using the TV remote, the input where the Wii is hooked up. This is the standard way.
Apr 10, 2011 | Mitsubishi Televison & Video
What do i need to play back recorded video onto my t.v from my sony handycam dcr-trv260...i have s cord, usb cord, yellow rca jack??? so what else do i need!!!...nothing i have tried has worked???please...
You can connect this camera to a suitable TV with either the S-Video lead or the RCA lead, but only if the TV is equipped with the appropriate inputs. The S-Video lead looks like a tiny DIN plug, and the RCA jacks are three separate plugs coloured red, white and yellow (yellow is composite video, red and white are left and right stereo sound). If you use S-Video you will also need to make a separate connection for sound (using the red and white RCA connectors). Sometimes the TV sound input is a mini stereo jack, and you will need a Y connector to adapt the two RCA connectors to the mini jack, or maybe the camera's sound output is also by mini jack, in which case you may need the reverse Y connector. Most TVs have some way of accepting a video signal, but you may already be using it for a DVD player or the like.
If your TV lacks these connections, you may be able to use an adapter. In the UK, most recent TVs have a SCART (Peritel) socket, which takes a big plug with 21 connections on it. You can get an adapter to fit that socket that will allow you to plug in the RCA connectors and maybe the S-video too. I don't know what country you are in, or what adapters are available in your country if it isn't the UK.
Once you have made the connections, you must select the appropriate input on your TV. The other possible hiccup is setting the camera to the right video standard, NTSC or PAL., to match that used by your TV.
The USB cord will not connect your camera to the TV.
Jan 11, 2011 | Sony Handycam DCR-TRV260 Digital Camcorder
Can't get signal to TV with AV cable
may have a proprietary cable format. try switching up the colors on the TV end (red to yellow / white to yellow.)
may work, depending on the cable you bought.
Nov 07, 2008 | Nikon Coolpix 4500 Digital Camera
Hook up video game or karaoke
If there is no video jack on this type of TV then you need an adapter to use the cable jack.
Sep 16, 2007 | Symphonic ST420FF 20" TV
DVD player hook-up problem
Using the composite video connection method is pretty straightforward. you will be dealing with one video cable (marked in Yellow), and two audio cables (marked in White and Red) Red is right channel and white is left channel if stereo, if mono use the white marked cable. Look at the back of your DVD player you will see the video out RCA jack (marked in yellow) plug one end of the video cable into this jack, the plug the other end of the cable into the TVs Video In jack (marked in yellow) Then plug the audio cables into the Audio Out RCA jacks of the DVD player Red marked cable to red jack White Marked cable to white jack. After this is done plug the ends of the sother side of the cable into the Audio input of the TV white to white, red to red. At this point you should have video and audio once you set the menu of your tv to accept input from the Composite input and the audio jacks. I hope this helps.
Sep 10, 2007 | Televison & Video
Symphonic ST420FF 20" TV Logo
66 people viewed this question
Top Symphonic Televison & Video Experts
Steve Allison
Steve Allison
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
