Question about Symphonic ST420FF 20" TV
Hook up video game or karaoke
I am trying to figure out how to hook up my karaoke machine to the WF20L6. On my other tvs, I just plug it into the yellow jack and set the tv to a "game" setting or Video 1, or Video 2, etc. Does anybody know what I need to do? Thanks so much JustJude
    Problem Solver:
  • 8 Answers
If there is no video jack on this type of TV then you need an adapter to use the cable jack.
Posted on Sep 16, 2007
SOURCE:
GPX Karaoke Machine with AM/FM radio and cassette, Manufactured 1/2001 Model C1550 do not know how to hook up to TV/VCR ?
On the rear of the unit, the RCA jack on the lower left corner of the jack panel should be yellow and marked Video out. take a RCA to RCA plug into the video out on the unit, then plug the other end into Video in on the TV.
I'll attempt to send you the manual thru the link below:
http://www.gpx.com/owners_manuals/JM250S-IB.pdf
Good Luck, and don't forget to rate the answer. Let me know if this doesn't help.
M
Sep 21, 2011 | Digital Products International Karaoke...
I got a wii and tried to hook it up to my toshiba tv and when i turned on my wii it was black and white and im positive i have it set up correct or if its just the cords itself the colors are blue green...
Make sure the plugs EXACTLY match the jacks on the TV. If you plug just the green cord into the TVs yellow jack, you will get black and white. If your tv has a combo jack (uses the green of a component input, make sure that the tv is on the right input (COMPONENT and not VIDEO).
let me know.
Jul 04, 2011 | Nintendo Wii Console
I cant connect my wii to my tv. can you give me instructions how?
Most TVs have a yellow video and a white audio and red audio input. The Wii comes with a cable to connect to a TV with a yellow, white and red RCA cable. Plug in the large block end of this cable to the Wii (rectangle block) and the other end into the TV using the yellow plug to the yellow input jack and the white plug to the white input jack and red to red. Select on the TV using the TV remote, the input where the Wii is hooked up. This is the standard way.
Apr 10, 2011 | Mitsubishi Televison & Video
Can't hook vcr to tv
on the back of your VCR there will be a yellow colored port - most likely labeled "OUT" as well as possibly a white/red pair of ports.
The yellow is for a VIDEO hookup, the white and red are for AUDIO hookups.
These ports use what is called an RCA type connection.
Radio Shack, or just about any department store should be able to sell you an inexpensive set of RCA cables.
now on the back of the TV (possibly on the side) you will also have the yellow, white and red ports.
Hook one end of the RCA cable to the colored ports on the VCR, the other end of the cable to the colored ports on the TV.
last thing - the TV most likely has multiple inputs. there is probably a input button on the TVs remote, you need to press that button to cycle through the inputs until you get to the one the VCR is hooked up to.
its easiest to put a tape in the VCR and press play - when you get to the right input, you will see your tape...
good luck
Apr 05, 2010 | Dynex DX-L32-10A 32" LCD HDTV
Screen goes blue on digilogic tv we have it set up with karoke machine we can get volume but no lyrics come up .
Blue screen on most TVs indicates that it is not able to see a signal on the input that is chosen. Most TVs have multiple inputs now, and some of the connectors share the same colors as well. I am betting that your karaoke box uses a 3 wire cable that comes out, 1 red, 1 white, 1 yellow that should go to the composite input on the TV. Here is the problem with that kind of cable. Very easily damaged. If you are sure that the input is set correctly on the TV, try replacing the cable.
Nov 02, 2009 | Audiovox Televison & Video
2-second delay with Magic Sing
i bought et18k. just the same as yours.its 2 days old and has the same problem. the technical assistant says that its because of the digital setting that new tvs have. there are two ways to solve this though:
1. connect the video (yellow plug) to the tv. and the other two plugs (yellow and white) to the stereo. when i say stereo, its not the dvd home theater system that you have but a separate one. if you connect it to the home theater that you have, it'll just sound the same, you still have the delay.
2. connect the magic sing to the older tvs hangin out. and you'll get no problem at all.
**TVs such as sony, samsung, philips, sharp and all plasma tvs including other newly designed tvs will have the delay since they all share the HDMI thingy that causes sh*t.
Aug 20, 2009 | Magic Sing Along Consumer Microphone
Hooking up a dvd player
Red and white are audio cables
Yellow is video.
Your problem is that your TV has no video inputs. TVs use those red white and yellow plugs to transmit the signal via those cables.
By cable box - do you mean a digital box? You can't run it through that unforunately - those connections are only for the box itself and it only has an output.
You'll have to go either:
Buy a new TV
or get an RCA Modulator.
Dec 12, 2008 | Durabrand DWT2405 24" TV
DVD player hook-up problem
Using the composite video connection method is pretty straightforward. you will be dealing with one video cable (marked in Yellow), and two audio cables (marked in White and Red) Red is right channel and white is left channel if stereo, if mono use the white marked cable. Look at the back of your DVD player you will see the video out RCA jack (marked in yellow) plug one end of the video cable into this jack, the plug the other end of the cable into the TVs Video In jack (marked in yellow) Then plug the audio cables into the Audio Out RCA jacks of the DVD player Red marked cable to red jack White Marked cable to white jack. After this is done plug the ends of the sother side of the cable into the Audio input of the TV white to white, red to red. At this point you should have video and audio once you set the menu of your tv to accept input from the Composite input and the audio jacks. I hope this helps.
Sep 10, 2007 | Televison & Video
Symphonic ST420FF 20" TV Logo
93 people viewed this question
Top Symphonic Televison & Video Experts
Steve Allison
Steve Allison
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
