Question about HP 920 Plain Paper Fax
How do you load document to send fax. With letter facing you or facing down. Model HP 920
  • 326 Answers
There should be an icon on the device showing a rectangle and what appears to be a triangle on top of it. This is showing you a folded page. If there are no lines on the rectangle with lines on the triangle then you insert the page face down (print on page towards the device) if the rectangle has the lines and the triangle doesn't, you insert face up (print facing you while in the inserting into the machine)
If you have any more concerns address your owners manual, this can usually be found on a CD that came with your printer or at HP's support website.
Let us know if you have any other issues.
Posted on Apr 16, 2009
Face up or down on hp 640 faxes
Load the documents face down in the document feeder. (Print side towards the fax machine.)
HP offers a lot of support for their products. The User Manual for the HP 640 is available here: http://h10032.www1.hp.com/ctg/Manual/c01094202.pdf .
I hope this helps.
Jun 19, 2012 | HP Fax 640
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
Can not send fax. The receving fax rings but my machine does not respond and send the fax. I can receive ok.
The document does not feed into the machine.
Be sure the document is not wrinkled, and you are putting it in correctly. Check that the document is the right size and not too thick or too thin. (See document types and sizes on page 43).
You cannot receive faxes automatically. Check if "TEL" appears on the right side of the display. In TEL mode, you
cannot receive a fax automatically. Be sure the handset is seated on the cradle properly.
The machine cannot receive faxes manually. Do not hang up the handset before pressing Start/Enter to receive a
fax.
The machine does not send anything. Check that the document is loaded face down. Send should show up
in the display after it dials. Check if the machine to which you are sending can receive your fax.
Dec 22, 2010 | HP 1010 Plain Paper Thermal Fax
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
Can not clear "document loaded" notification.... shows on start up, and cannot send fax.
Open top cover and check if there a little piece of paper stuck on the document sensor in the scan area or the sensor could be out of position.
Oct 03, 2009 | HP 920 Plain Paper Fax
Fax machine works good but I bought it at an auction sale and when you send a fax it has the former owner name and fax number on it. I need to change this info to my name & fax# and don't have a manuel...
To change the fax header from the front pannel:
Press Menu , then 7 , then 2 . Enter your fax number and name to be printed on all outgoing faxes. NOTE: In some locations this is a legal requirement. Entering text Press the keypad numbers corresponding to the letters you need. It will cycle through the lower case, then the upper case of each letter. Press the right arrow button (also the Speed Dial button) to advance to the next space. Example: Pressing number 2 once = a, twice = b, three times = c, four times = A, five times = B, six times = C, seven times = 2. *** You can get support for your printer (i.e., download drivers, software, manual an other documentation and access FAQs and How-Tos for your printer) from HP, here: http://h10025.www1.hp.com/ewfrf/wc/product?product=58854&lc=en&cc=us&dlc=en&lang=en&cc=us
Aug 20, 2009 | Office Equipment & Supplies
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Fax, Copier, Scanner and Printer #4540
thank you for choosing Fixya.com.
sending the document using fax machine always remember that the proper position is to face down the documents,
hope i help you on this matter.
please don't forget to rate our answers properly.
Feb 23, 2009 | HP Easy Refill Kit for (HP) Color Inkjet...
Cannot send a fax conventionally - can you describe how I should send i.e. not through the glass
Place document in document feeder, dial number, press send or start.
look for an icon on the feed tray to signify face-up or face-down.
Sep 11, 2008 | HP Office Equipment & Supplies
Help
Most faxes are face down. check the symbol on the paper input, there is a symbol of a paper with the left corner bent. This means face down
Dec 12, 2007 | HP 920 Plain Paper Fax
HP 920 Plain Paper Fax Logo
326 people viewed this question
Seeker5211
Seeker5211
