Question about Onkyo HT-SR700 System
Problem with Onkyo HT-SR700
I bought the Onkyo HT-SR700 system and I have connected Cyberhome (DVD) with the same and the TV. When I am using the HT, the sound is not coming as I expected. I can hardly hear the surround effect and the back speaker has very low volume. Please suggest as to how should I configure the system to blow the head apart from its sound.
  • thisisnikhil Sep 17, 2007
    I have a Coaxial cable attached from DVD player to the receiver on the ports that are specific to coaxial cables only. That is one. The second connection is thru a normal Yellow colored port for video input output from DVD to teh receiver. These are the only two connections from DVD to receiver. The last connection is from receiver to TV for video.
    Also, suggest me the best mode of playing and the speakers volume settings etc. to get the most out of the system.
    Thanks in advance!
  • 65 Answers
Can you explain how you have the DVD player connected to the reciever and what the label on the jacks read on each.
Posted on Sep 16, 2007
  • Hatters church organ
    Hatters church organ Sep 17, 2007
    OK. The coax on the back of the reciever is not for video, it is to plug in an FM antenna if needed. If it were me (and this is how my home theater system is set up)I would not use the reciever for any video at all. My opinion is that it adds too many links in the chain. I would use it for audio only. Really the only reason it would be needed is if you had multiple sources of video and not enough inputs on you TV.
    -On the back of the reciever on the left, you should see an RCA style input marked Coaxial, in the Digil In box. That is to be plugged into the DVD player audio labled with a similar label. The reason for connecting it this way is because it is a data connection, which means they actually communicate with each other. A DVD is encoded with information and the DVD player will give that information to the reciever which tells if how it should set itself up for perfect playback. In other words, it's totally automatic, and it's the best possible sound! Super easy.
    -For the video, it totally depends what kind of TV you have as there are many ways to configure the video. If you are using a tube TV, you will probably want to use a coax between the two. If you have a high definition tv or some projection sceen, you will likeky have a component video input. That is the best to use if it is available because that is the one that sends true high definition video.
    To play a DVD, you will have to use the reciever for audio and set your TV to whater input you decide to use.
    Crutchfield.com has some cool DIY pages to help you understand all this stuff a little better.
    Good luck and don't forget to leave feedback!
    Dan "The Mad" Hatter
    I meant to say "Digital Box" there on the 8th line
Onkyo HT-R520 no sound
i did a factory reset on mine. it had the classic problems. no sound from any input except the tape input. after i did a factory reset they all seem to work.. we shall see for how long...
Jan 20, 2010 | Onkyo HT-SR700 System
Onkyo receiver memory power backup not working
How change battery and the battery model
Dec 22, 2009 | Onkyo TX-SR700 Receiver
My Onkyo Tx-Sr700 sound is not working. I have speakers connected for surr. sound but I can't figure out what buttons to press to turn them on for tv. Tv is video 1
make sure you have audio cables connected from your cable providers audio out to your receivers audio in on video 1 press the video 1 button you should hear the sound.
Oct 16, 2009 | Onkyo TX-SR700 Receiver
No sound it last night trun back on the next wont work
have all the speakers been reconnected? if so, there may be a blown output fuse inside the reciever.
Dec 03, 2008 | Onkyo HT-SR700 System
Power, but no sound coming from my speakers, checked fuses.
i have power but no sound it worked fine for a little while yesterday but it stopped whats wrong wit it
Mar 04, 2008 | Onkyo HT-SR700 System
Dvd connection
Yes! You can pass the video signal through the receiver. This is most useful when you have more than one video device (e.g. DVD, cable box, VCR,...), and you can use the receiver to switch to the audio and video for the selected source at the same time.
On the back of your Onkyo HT-SR800 there is a section labeled "Component Video." It has three inputs and one output. So, attach your DVD by component cables to the "DVD In" and then attach component cables from the "OUT" receiver connection to the TV.
If your TV doesn't have a component connection, then this addresses your other question. You can't gain anything with this, because your TV doesn't support it. Connect the DVD to the TV according to the highest quality connection that they both support, in this order: composite, S-Video, component.
If you are using composite, but they both handle composite, than yes, you will get a better picture by going to component (or even S-Video). If both devices support progressive scan, this could be a substantial difference.
Your receiver accepts component, s-video and component video, but keep in mind, it may not do "video switching." So if you connect the DVD in via component, but go out to the TV over composite, then you may not get any video at all (but feel free to try). Try to avoid this, but you may be forced to try depending on the limitations of the various devices that you are hooking up.
Jan 16, 2008 | Onkyo HT-SR800 System
Onkyo HT-SR750
Check out Onkyo's website: The HT-SR 800 description says "a separate audio connection is necessary" Maybe it is true for the --750 too.
Jan 01, 2008 | Onkyo TX-SR605 Receiver
Onkyo HT-R520
Hello the HT-R520 is the model of the receiver that is part of the HT-S770 package. I suggest that you check the speaker settings. Check the level of the center speaker. If you need assistance please contact Onkyo at 800-229-1687 option #3. Thank you, Onkyo USA
Jul 02, 2017 | Onkyo HT-SR700 System
Onkyo HT-SR700 System Logo
189 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
