Question about Dell Dimension 4600 PC Desktop
"dancing" stripes and bands across monitor
It often boots up fine, but within a few minutes I have those light colored bands getting progressively worse, until the screen starts to become impossible to read. Then it turns a blue-green, and obscures verything. After that, if I stop using it, it will sometimes clear up again.
  • 298 Answers
This could be a Graphics card heat issue, Have you checked the inside of your case for dust lately?
If thats not it check for updated drivers.
Posted on Apr 16, 2009
KD-34XBR970 CRT HDTV startup problem
This is a failure in the vertical amp section. One way to troubleshoot it is to get a can of freeze spray and use it on the suspect components. The other way is to inspect all the solder joints on the amp. Last would be to check voltages on the board. Since it does change with run time, it is being affected by heat.
Mar 12, 2017 | Televison & Video
Color separation ~ Insignia 32" NS-LCD32
1. Unplug unit from wall for 3 minutes;
2. Press & hold Power button for 1 minute;
3. Plug in unit.
OR:
1. Unplug for 3 minutes.
2. Plug in unit.
3. HOLD Power Button as unit starts ... hold until the unit flickers on then off twice.
This effectively returns the components to factory specs, much like resetting a computer. It offers a *temporary* fix, lasting 45 minutes to hours. All depends on the unit.
Mom has an Insignia 32" with the same color separation problem, which worsens as the day progresses. Best results achieved while television is cold.
Dust in the unit could contribute to the problem ... try to keep the unit dust free as possible.
Sep 16, 2012 | Insignia NS-LCD32 LCD TV
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
Suffering from EXACT same problem. Also Dell UltraSharp 2001FP
This is heat, and is a common problem; it affects two of mine. You can verify this by having a can of Dustoff available and catching it when it first starts. Blow in at the top of the monitor through the holes in the back in the same region as the band. The color aberration should go away.
My solution was to make a shroud from black foamcore and use a spare power supply fan to blow air into the case at the top. This has worked for my two monitors for about 18 months. You can also just buy a 12v computer cooling fan for this purpose.Should be somewhere around 75mm in size and quiet, 'cuz you'll be putting up with it if it's not.You can either get a general 12v power supply, or an adapter that fits the 12v power out at the back next to the USB input connector.
Sep 04, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Graphics card or motherboard problems...
You've run the antivirus. Next, try to run malware & spyware programs. THen, run a good registry cleaner. This will aim the right things with the right things. If you made ANY changes to hardware, software, programs or data, there will be changes in your registry.
Jul 15, 2009 | Gateway FX7026 PC Desktop
Display problems
Macrovision
An analog video copy protection scheme that alters the unseen part of a video signal such that a VCR or other macrovision enabled device may not record the video signal properly. There are several types:
- Automatic Gain Control
- 2-line color stripe
- 4-line color stripe
Symptoms of this include picture fading in and out or color banding of the signal.
Feb 06, 2008 | Zenith DVC2200 DVD Player
Monitor or Video Card?
Looks pretty much like you have a defective monitor. Have you tried serviceing?
Apr 27, 2007 | Dell UltraSharp 1703FP 17" Flat Panel LCD...
Dell Dimension 4600 PC Desktop Logo
82 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
