Question about Hitachi 43FDX01B TV
HDTV Convergence problems
Unable to get my hdtv adjust. I go through the convergence setup as indicated by the manual but at the end I still get that double line. for example I will see the any words on the screen will be written twice one in red and the other in green.
  • Anonymous Apr 18, 2009
    Same as noted
  • chlamb May 11, 2010
    auto (magic focus) doesn't seem to help but I can adjust manually it "fixes" the problem although it leaves me with a distorted upper left part of screen (now in focus). I spent probably 10 minutes fixing it last night but it was off again tonight without ever moving the tv.
  • 1,153 Answers
Does the convergence change, do you have the auto or manual. Look for the manual and try to adjust yourself if not then there is some resistors bad on your convergence board.
Posted on Sep 16, 2007
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
How do I adjust the convergance? I have a shadowing problem
Press menu on the remote then scroll down to setup then enter setup. The auto convergence feature is listed there which will reset it automatically. If auto convergence disappeared from the setup menu then you will need the RCA convergence option missing repair kit from which does contain the instructions.
Jun 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" Convergence Problem
Replace the convergence power supply. You can get the ITC222A convergence power supply board at the following link under RCA circuit boards.
Jul 24, 2009 | RCA HD52W59 HDTV Projection Television
Screen looks 3d and schrunk
this is an indication of convergence failure. on these model the first suggestion or more like question is this do you have the convergence option in the customer setup menu? If you dont i suggest you read the fl231 problem in the tips and tricks section of this website. If you do and you still have the bow tie three d effect then the next solution is to replace what is known as convergence power supply. note when you start replaceing the boards that effect convergence it may need adjusting that a technician needs to do
May 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence problem on rca model d52w23
Replace convergence board or repair it. Try this with TV off Press and hold vol-and ch- at same time hold untill set comes on Now you should be in service menu Go to convergence Adjust the 16x9 mode.
Dec 21, 2008 | RCA D52W23 52" HDTV CRT TV
Green convergence not synced
I thing your problem is in convergence output it require Technicain job I can give part No. to order from Samsung but you still need to adjust convergence after you replace that part the adjustment require remote control and service manual and patient for instruction how to do convergence I can post it to you OK
now part No. is BP94-01259G or L
Nov 18, 2008 | Samsung HC-P4752W 47" Rear Projection...
customer convergence is under setup in customer menu. if you do not have this you might have the "fl231 fuse problem. this set has no convergence ic.. uses a series of transistors
Nov 04, 2008 | RCA HD52W59 HDTV Projection Television
Rca projection tv
this is a indication of convergence problem. the curved picture indicates total or a complete loss of convergence power. I first recomend you read the artilce in tips in tricks section. the fl231 problem it might be this if you do not have the convergence options in setup of customer menu. if not it might be a convergence power board issue
Oct 12, 2008 | RCA HD52W59 HDTV Projection Television
Double vision tv
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 43FDX01B TV Logo
216 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
