Question about Maytag Neptune MAH6700A Front Load Washer
Washer will not drain or run. It gives a code nd
My washer started beeping and showing a code nd. The washer is a Maytag neptune MAH6700AWW model.
    New Friend:
  • 3 Answers
Mine doing same thing, "ND" code coming up. I just replaced pump, 1/2 way thru wash same code came up. Blew out hose going into main house drain, also house drain. Still not working. Is there a trap somewhere or what am I missing? A reset maybe? Help thanks
Posted on Jun 25, 2016
    Champion:
  • 219 Answers
Pull back off washer and check your waterpump
Posted on Apr 17, 2009
SOURCE:
Code nd
Don't know if this is your problem but sometimes ours will appear to drain, but there is still a lot of suds that remains and trips the nd (no drain) indicator/lockout. We had to pour water in from a bucket to beat down the suds, then repeat several times to get all the suds out. First time I took off the back of the washer, disconnected the pump, then let the suds out. To much work.
Nov 11, 2013 | Maytag MAH6700AWW Neptune Front-Load...
We replaced pump on our Maytag neptune MAh6700AWW but we still got a nd code and it din't go into spin cycle?
cdmcdm5, did you ever figure out the solution to this problem? I currently have same issue. Have checked for obstructions multiple times and also ended up replacing pump. Still have same ND (no drain) code issue.
Jul 10, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Wont cycle get ND error message
The ND code means 'No Drain' and it is probably just something caught in the pump. I’ve seen where a coin can get in there and keep the pump from starting.
Some other items known to stop a Neptune pump: Rubber backing from a rug, rubber bands, bobbie pin, lens from a flashlight, tooth pick and a bra wire. Maybe you had something different in your pump? If so, please comment with what you discovered in your pump...
If you have a floor drain you should be able to drop the discharge hose to the floor and let gravity pull the water out so you can take the pump out and get a good look at it.
Sep 02, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Pump on maytag neptune is clogged. control panel shows "nd" water won't drain from tub. help
you need to take the pump pipes off to clear it also look for filters and clear them the only way to get to the pump is from the back,,,
Aug 08, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Duet model GHW9100Lwl We get an H code and F code?
H and F code flashing alternately could be one or more of the following items not working properly or bad:
- Flowmeter.
- Water inlet valve
- Water pressure switch. (last thing to replace)
Make sure to unplug power cord before you replace the part and also make to clean drain tube and filter every year.
Get back if you still have problem.
Jun 15, 2010 | Maytag MAH6700AWW Neptune Front-Load...
How do i fix nd code for mde5500ayw maytag neptune
There are two possible causes to the "nd" code. The first is with the pump itself. Either is is blocked or it is simply worn out and needs replacing. The second is a malfunction with the control board. Unless you find a blockage to the pump there is no way to know which one is the cause of the "nd" code without some testing or replace these items.
If you are unafraid of facing your washer with tools in hand then you should be able to test the pump. As for the board, all you can do is check it for damage most likely caused from a component melt down. In which case it's going to need replacement.
But check for blockages first because that will cause the "nd" code.
I hope this helps and good luck.
Oct 06, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH6700AWW water won't drain into drum
Power off the wall. Drain water & check your pump for blockage. Filter as well.
Mar 26, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH6700A Front Load Washer Logo
773 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
