Question about Refrigerators
How to reset and adjust temperatures on front panel
How to adjust the temperature on Coolpoint CX405
GSS23QG, GSS23QS, GSS25QG, GSS25QS. How do I reset the temperatures? They're now at 24 for the freezer and 48 for the refrigerator. Thank you!!
Posted on Jul 13, 2010
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
How do I adjust freezer temperature on Electrolux refrigerator?
Hello friend, thanks for your inquiry!
I see that you would like to know how to adjust the temperature within your Electrolux refrigerator, EI23CS55GS1. To adjust the temperature you would use the control panel on the front of the freezer door. There should be a "-"or "+" near the freezer temperature control and that is how you would adjust the temperature within your refrigerator. Be sure to check and make sure that the control lock is not on or you will not be able to adjust the temperature. Any adjustments made within the refrigerator need at least 24 hours to stabilize. I hope this is has been helpful. -Matt
Oct 18, 2014 | Electrolux Refrigerators
How do I set my settings for the frig and freezer?
Hi friend, thank you for your inquiry!
I understand that you are having difficulty with the temperature settings on your Frigidaire refrigerator. Depending on your refrigerator style on a top mount there should be a cold control on the inside of the fresh food side that would be used to adjust your temperature. On a side by side or French door bottom mount the temperature control is located on the front control panel. Typically, as a "+" or "-" symbol to adjust the temperature. If any adjustments are made to the temperature, please allow 24 hours for the temperature to set properly. I hope this information has been helpful. -Matt
Sep 28, 2014 | Frigidaire Refrigerators
How do you reset the display temperature
follow this steps and fix it. God bless you
    • 1
      Press the "Fridge" button on the refrigerator's front panel.
    • 2
      Press the "Fridge" button until there are more lights visible on the panel next to "Fridge" to set cooler temperatures.
    • 3
      Press the "Fridge" button until there are fewer lights visible on the panel next to "Fridge" to set warmer temperatures.
Read more: http://www.ehow.com/how_7696789_reset-temperature-samsung-refrigerator.html#ixzz2Ze3Som8U
Jul 21, 2013 | Samsung RS2630SH Side by Side Refrigerator
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
The back of the fridge is frozen and food is not getting cold anymore
Try this first:
Self Diagnostics
You need to cycle your freezer display to indicate 0 and your refrigerator display to 7.
Control and Sensor System Self-Test (0 7)
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display.
If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
Thermistor test results:
• P = Pass
• 0 = Failed
• S = Short to 5 VDC
• B = Bad amplifier
Thermistor test sequence is:
1. Fresh food top thermistor
2. Fresh food bottom thermistor
3. Quick chill thermistor (displays 0 if unit is not equipped with Quick Chill option)
4. Evaporator thermistor
5. Freezer thermistor
Note: Thermistor test results will be displayed in the sequence shown above. The thermistor test sequence number will not be shown on the display.
Note the failures if any. Should ANY of thermistors fail you must replace it.
Having said that... at this point your stick with doing a manual defrost by unplugging the unit and directing a fan into the compartment for just over 2 hours to make sure ALL of the ice on the coils and in the drains has melted. (Yes it makes a water mess!)
After the manual defrost restart the unit / plug it in and once the compressor starts listen for the evaporator fan when the door switch is actuated and the condenser fan in the bottom of the unit any time the compressor is running. If either of the fans are not running you must find out why. Can be a door switch, motor winding or power to the motor. The door switch does not affect the condenser fan.
Finally if the unit is not automatically defrosting due to a component failure... i.e
Heater, themistor, or wiring you will see ice build up again in 2 to 3 days again and you will have to keep going through the manual defrosting routine until the automatic defrosting problem is resolved.
Thanks for choosing FixYa.
Kelly
Mar 27, 2011 | GE Profile Stainless Bottom-Freezer...
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We just purchased a ge profile refrigerator today, and cannot get it off of demo mode
You have to go into the Diagnostic mode to see if you can reset this issue or if the main board in back is bad. Here's how to do it:
First, run the control and thermistor test:
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display. If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
• P = Pass
• 0 = Failed
• B = Bad amplifier
When testing has been completed, do the following :
• Enter code 1 5 to completely reset the system. Then press the Hold button (or any other button than a temperature button) to accept the code.
When you're done, unplug the refrigerator for 10 seconds and plug it in....if it does not run, the board is bad.
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
503 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
