Sharp CD-BA200 CD Shelf System Logo
Posted on Sep 16, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cd shelf will not open
When I press the cd open button to insert cd's I get an error message 0306 and it will not open.
Anonymous
Level 2:
  • Expert 82 Answers
  • Posted on Mar 25, 2008
Anonymous
Expert
Level 2:
Answers
82
Questions
0
Helped
54694
Points
137
There is a belt in the CD mechanism that may have to be replace. The part number of the belt is 92LBE231616.
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
How to turn on rca cd player
Hello
1. Press 'SOURCE' repetedely to select 'CD' mode.
2. Press "Open/Close" button to open the drawer.
3. Insert disce and press 'Open/Close' again, and the inserted CD will play automatically. OK.
How do you put all 5 cd's in a sa-ak33 panasonic cd player
press disk 1 open and insert the cd.
now press disc 2 open and insert cd.
same way do the rest.
8helpful
I am getting an error Message 0306 or 0203 when trying to open the cd tray on my Sharp CD-BA150 Stereo System what can I do to fix this problem
For the error 0306, simply remove the lid of your system and clear the dust out/off of the lense and surrounding areas. (i.e. soft cloth, canned air, ect...) Hope this helps!
CD-DP2500 error 0306.Disk changer error. What is cause ?? I got it going OK! after having a good look around checking laser head connections. It seems to have arrived with warmup. I cant find error codes...
how to open the code I wrote that has protection and ... I do not know how to open the electrically operated lights notwill to caress the Power but notwill.
2helpful
Error 0306
hi there, I suggest you should open the top cover of the cd tray, have a look inside do a little cleaning also when you screw back in, make sure you screw in properly( you propaply find that someone had open it up before and screw it back in really tight so the cd trey jam inside, or another alternative something might of broken inside and tha can stop the cd trey from opening. it happen to me before and thats how i fix it. good luck hope it works.. cheers
3helpful
Cd stuck err 0306 message
Since the cds are stuck inside, you need to open the unit and remove them. There are four screws on the top cover. Remove them (2 on each side) and lift the cover. You should see the cds, remove them, then plug on the unit.
1helpful
2answers
Cd tray won't open
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Sharp cd -bp 1350w
I think that depending on if it is old usally before it dies it starts not wanting to open disc drive add coment if it is old or new...
4helpful
Cd-ba200 error 0306
Check the CD belt. Part number 92LBE231616.
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
