Question about Kitchen Ranges
Whirlpool rf366pxyw bottom element replacement- have put in a new element but it still doesn't work. What is the resistance of the new element supposed to be?
    President:
  • 1,865 Answers
You need to troubleshoot the whole ciruit, from the control knob to the element
Posted on Apr 16, 2009
My dryer works - BUT it no longer is hot- I am sure it just the heating element and I am sure i can just replace that and it will work just fine again. WHirlpool Supreme. model LER7646EQO serial MG4337952...
IT DOES NOT HAVE TO BE THERMOSTAT PROBLEM. REMOVE BACK PANEL . THERMOTATE IS LOCATED AT THE BOTTOM OF THE HEATING PANEL . IF YOU ARE ABLE TO TEST RESISTANCE OF YOUR HITTING ELEMENT DO SO AND THAN TEST YOUR THERMOSTAT
Feb 27, 2011 | Whirlpool LER4634J Electric Dryer
Bottom element not working
Well, to ensure the element is bad, you can take an ohm meter to the contacts of it and measure the resistance. It should be around 20 ohms. If it is much greater or infinite, the element is bad. To get to the contacts you will need to unplug the oven, pull it away from the wall and remove the rear panel. Then disconnect the element wiring and touch the probes from the meter to the contacts on the element. You can order a new element locally or from repairclinic.com. Let me know what you find.
Benjamin
Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Replace thermocouple
Here is a manual for your water heater, I think it's actually an 82VH40-2
http://globalimageserver.com/fetchDocument.aspx?id=17bb6286-4eb8-4e44-813e-6ccfafda4404
An electric water doesn not have a "thermocouple" like a gas water heater does that senses pilot., Most electric hot water heater has two heating elements, two thermostats, with high temp cut outs. If your heater is not working, the elements could be bad. If you want to test, remove power to the water heater, disconnect wires from heater elements, and using an ohm meter measure resistance across the terminals. If it is open then the element is bad. You can compare readings from top and bottom elements. While the bottom element is on more often, if you're replacing one, I'd replace both. The water heater will have to be completely drained in order to do this. If the elements are ok, then you can test the thermostats the same way. It would have been better if you could have described your problem
Aug 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I'd like to know how to change a heating element in my dryer (29' whirlpool) I'd like to know exactly how to take it apart and where to find the element. I'am not sure of the dryer #
first you nead to unplug the dryer,next you nead to remove the vent hose,next you nead to remove the back panal and the power cord cover,on the left side you will see the heater housing,at the bottom you will see the heating element,there are four wires,the two at the bottom are hooked to the element,you nead to pull them off,the other two wires are hooked to the high limit switch,you nead to pull them off,next there are two 1/4"screws,one on each side off the heating element,remove them,now pull out on the bottom of element,with element removed,remove the high limit switch from old element and put it on the new element,take new element and put it back in the heater housing and replace the two 1/4" screws,you will see that the two wires that go to the element are biger than the two going to the high limit switch,put the two wires to the element,now replace the two wires to the high limit switch,replace the back panal and the power cord cover,replace the vent hose,plug power cord in and check element out.
Nov 25, 2009 | Whirlpool LER5636P Electric Dryer
Bottom element doesn't work on oven - original element blew out (big piece came out of it) - replaced with new one. Top element works, bottom doesn't. Vintage of electric stove/oven is late 80's. There...
check the new coil for resistance with a volt ohm meter. if you have the meter on ohms (resistance) and it shows to be open ( no resistance) the coil is bad.
VERY CAREFULLY set the meter to ac voltage if the probe will stay in the plug where the coil plugs in insert the probes one in each side and turn on bake to see if you have any voltage. if no voltage you will need to check your thermostat and control / temperature switch.
Nov 15, 2009 | Cell Phones
Heating element not working on a ele ctric dryer
With the power disconnected you can check the resistance of the heating element. Remove the back of the dryer. Remove the connectors to the element and if the resistance measured is any greater than 25 Ohms then the element will need replacing. If the element is OK then check the thermal fuse(s) or thermistor on top of the housing which are there to present overheating. That’s really all there is to it if the motor is running and the timer id working OK.
Oct 30, 2009 | Whirlpool Dryers
Hidden bottom element not heating. Went to remove it and it had burnt through. New element doesn't get hot.
Assuming that you installed the replacement correctly, can you check the element with a resistance meter?
It's possible the replacement element you bought was faulty. But first, we want to ensure that the oven is otherwise functioning correctly. You'll need that resistance meter to check continuity along the red wire (i'm presuming) that connects your top and bottom element to your selector knob. Also make sure there are no internal fuses in your oven that may have blown.
Please remember to turn the oven off at the breaker board before working inside it.
Hope this helps, let me know.
John
May 09, 2009 | Kitchen Ranges
Bottom Element Open Circuit & Fan Element not working
No resistance in a bake element is a bad element. Replace it.
Most fan come on with a rise in heat. No heat/no fan.
Apr 08, 2009 | DeLonghi Ovens
Kitchen Ranges Logo
167 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
