Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Mitsubishi VS-50705
Lines through tv and on top edge rainbow. changed all cords, plugged into cable directly. Definitely the tv how do I fix it.
    Genius:
  • 1,153 Answers
VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Posted on Sep 18, 2007
SOURCE:
I have a Mitsubishi VS-50705. It's a 50inch rear projection TV. The TV only allows me to switch between the ANT A and ANT B inputs, none of the others. When I plug in cable to either ANT A or ANT B nothing...
Hi con,
Welcome to FixYa.
My name is John.
I will be assisting you with your issue.
Go to SET-UP in the MENU.
Then do a CHANNEL SCAN or AUTO PROGRAM SCAN.
You should be good to go..
Thanks for choosing FixYa.
John
Jan 06, 2011 | Mitsubishi VS-50705 50" Rear Projection...
I have a Mitsubishi Rear Projection tv (vs-50705). The picture shows a concave image on the top and bottom of screen and the edges go off the screen. I have red blue and green ghost images on the screen...
Well, you did the right first step. However, when the convergence outputs toast up they sometimes cause other problems. First would be the fuses that supply them voltage. These are pico fuses back in the power supply. Second would be open supply resistors that have opened up because of the excessive current draw caused by the whacked out convergence amps. When changing the outputs doesn't solve the problem it takes the repair out of the realm of the do-it-yourselfer. My recommendation is to let a professional take over.
Jun 06, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi vs-50800
take a look at the gun at theback of TV. if you don't see the beam. it is definitely the HV. I don't know it is worth fixing it. then, there may be something else is going too.
I did it once it is just not worth the time and money.
Sep 02, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Rolling picture
Try replaceing capacitors C2C52 10uf 50V capacitor and also C2P05 100uf 16V capacitor. these are both on the signal board. It that doesnt correct the issue replace IC2P01 which is the 9volt regulator also located on the signal board. That should take care of your problem
Jun 08, 2008 | Mitsubishi VS-50705 50" Rear Projection...
No sound on 3 channels
Check if the sound adjustment is in STEREO-SAP-MONO mode
Change to STEREO mode
Jun 02, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50va2 50 in. projection tv
You need go to set up andjustment mode and change the option of HOME THEATER to OFF position.
May 31, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi vs-50705
Maybe you have a problem with the Vertical out, and you need change it.
May 07, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi tv
D980 also you can change C411,412
Mar 10, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
123 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
