Question about Technics SL-1210 Turntable
Technics 1210 MK11 - 'Click' in tone arm movement
I've had a problem with needles jumping on some records for a while now. On further investigation this seems to be linked to a click on the tone arm movement. This click is not present on my other deck which has no such problems. Basically if you move the arm from side to side it 'clicks' at a consistant point, about 2/3 across the movement range from out to in. It moves fine before and after this point. Any ideas on what this is and how it might be fixed?
  • 515 Answers
Your tonearm is damaged at the pivoting screw. Unfortunately, there is no easy way to fix this other than replacing your tonearm. The pivoting screw is a cone shape screw - aka conical screw - and this sits on 4 ball bearings, with a very thin piece of sheet metal which keeps the ball bearings in place. If this thin piece of metal is damaged - more than likely indented - it causes this sort of clicking sound you speak of. You will need to have the tonearm replaced, as this cannot be fixed. Or, shall I say, it will cost you more to try and fix the problem than it will to just replace the tonearm:
FIX = 3-6hrs @ $85/hr
or
REPLACE = 1hr @ $85 + $70 (tonearm)
You do the math.
Technics Tonearm can be purchased here, but this is not an easy replacement, and you could do more damage if you are not sure of what your doing. Professional repair is recommended. You can buy the part, then bring it to the service shop.
- OPTiC
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Apr 30, 2009
    Brigadier General:
  • 8,546 Answers
It's clearly a mechanical interference under the hood, so to speak. If you're comfortable with this, unplug the power and signal from the TT, remove platter and manually rotate the tonearm across its arc, listening or feeling for the drag. Maybe you will see the cause with the platter off.
If not, remove the headshell so it won't be damaged, remove the turntable from its base and lay it upside-down, being careful to keep the platter engaged so it doesn't fall off, on a thick soft fleece blanket supporting the whole thing by the platter so nothing stresses or interferes with the tonearm. Once again, rotate the tonearm and observe. I'm sure you'll hear or feel where the problem is. The next trick would be to resolve it.
I have an old Dual 1249 that had the same sympton as yours and it was a mechanical binding near the mechanical pivot area beneath the base. One of the links to the auto-eject mechanism was rubbing and you could see the wear on it. The tonearm assembly had come unseated in its cut-out and I just pressed down on it (from its normal top) and it popped back into place, about 1 mm. Voila! Fixed.
Posted on Apr 21, 2009
I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Feb 20, 2012 | Technics Audio Players & Recorders
Tone arm skipping records.
The anti skate adjustment. And if you scratch @ all....move the weight all the way in and take off the little extra one that screws in on the back. Also a great tracking needle is a M44G.
Mar 03, 2010 | Technics SL-1200 Turntable
Tone arm pulls back on my technics 1210s
your needles gone.or you've moved the tip by touching it.
try & twist the tip back straight.
A LITTLE TIP FOR YOU ....u should never wipe or
touch the tip of a needle with your fingers coz the greese off your skin ***** them.blow it or use a little fine brush.
Aug 04, 2009 | Technics SL-1210 Turntable
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
Technics 1210 tone arm Problem
This table should have an "anti-skate" adjustment. This is out of adjustment and putting to much tension on the arm. This adjustment is designed to insure that the needle tracks in the middle of the groove rather than one side. If the arm is out of balance and this os out of adjustment, the symptom you describe will occur. Hope this helps, Dan
Jun 08, 2009 | Technics SL-1210 Turntable
Needle Skates
If you're a real DJ then the Technics is the best TT to scratch on. Don't listen to that fool about not scratching, lol. Your tone arm could be the problem. Have it checked out. I repair TT's
Mar 18, 2009 | Technics SL-1210 Turntable
Tone arm trouble i think???
this is a damaged tone arm bearing i had this problem with mine and had no choice other than spending £50 on a new tone arm
Mar 08, 2009 | Technics SL-1210 Turntable
When i backspin the arm is forcing itself off the vinyl
IMO the problem can be solved in 2 ways, either move the counterweight on the back of the arm towards the turning point of the arm ( by just adjusting it 10 - 20 % of an whole spin you can adjust a lot), or buy an other needle which is heavier then this one...
Jan 29, 2009 | Technics SL-1210 Turntable
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
Technics SL-1210 Turntable Logo
326 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
