Question about Toshiba Satellite A205-S4607 Notebook PC
My Toshiba Satellite A-205-S4607 camera does not turn on. There is no preview.  Camera toolbar is there.  When the start camera button is pressed a small blank window opens.  But there is no picture or preview.  I used to see myself in the preview window.  Not so now.
My toshiba a205 s4607 is stuck at the welcome screen.. i tried pressing f12 but nothing happens. when i press f2 it just says please wait and never works. i dont know whats wrong. i want to reformat it but...
I don't think it is your hard drive but here is what you could do:
Press F8 at start up to enter start options, choose safe mode with networking or last known good configuration.
Use the built in system recovery, press F11 or F12 at start up to enter recovery partition.
Use a set of recovery disc to do a system repair or to install new original operating system.
Order the recovery disc set from the website by model and serial number.
PCHELPSTER007 from youtube
Jun 25, 2011 | Toshiba Satellite A205-S4607 Notebook PC
How do I use the integrated web cam on my Toshiba Satellite laptop?
There are several ways you can use the camera on your toshiba laptop.
1.) Use a program such as Skype or Windows Messenger; these programs will only use your web camera when you video chat with someone else over the internet.
2.) Alternatively, most Toshiba laptops come with a built in program that you can use to activate the web camera, and you may even be able to record videos and take pictures. This program is usually found in a toolbar on the side of your screen. To use it, move your mouse cursor to the left side of your screen, and something should pop out. The camera can be activated from there.
3.) If this does not work, clicking on the start button (the circular windows logo found in the bottom left corner of the screen) and typing in camera should bring up a program called 'camera assistant.' Clicking on this should also start up the camera software.
Feb 28, 2011 | Toshiba Computers & Internet
I would like to know the price of toshiba satellite A205-S4607
$1455
http://www.memory4less.com/m4l_itemdetail.aspx?partno=PSAF0U-02C009&itemid=1455901813&rid=fd_10
Feb 14, 2011 | Toshiba Satellite A205-S4607 Notebook PC
Toshiba Satellite A205-S4607 Audio Driver on Windows 7 x86
Instructions to Fix Windows Error Code 0x00000017:
Apr 12, 2017 | Toshiba Satellite A205-S4607 Notebook PC
Toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS ESC Toshiba Protege ESC Toshiba Satellite 205 CDS F1 Toshiba Tecra ESC then F1 or F2 Toshiba Notebook [Newer models]
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
Nov 04, 2009 | Toshiba Satellite 1415-S173 Notebook
Camera for my toshiba is not turning on
There is a Fn button located at the bottom left corner of your keyboard.......press this along with the F6 key to switch your camera on and off.
Oct 07, 2009 | Toshiba Satellite A305-S6857 Laptop
Problem with Toshiba A205-S4707 Built in Web Cam
have you knocked the laptop at all?
you may have disconnected it by accident. probably not but its possible. if you have a accidental coverage then you're fine.or house insurance which covers it.
Jan 22, 2009 | Toshiba Satellite A205-S4607 Notebook PC
How to turn on the camera?
Try pressing the Fn key followed by one of the F keys (numbered 1-12) on your keyboard.
Jan 05, 2009 | Toshiba Satellite A135-S4527 Notebook
Lens error
This can work with CoolPix S10
1) Remove battery.
2) Replace Battery (Insure it is fully charged)
3) Press the Shooting/Preview button and keep pressing it while you press the power on button. This tells the camera to go into PREVIEW MODE without checking the lens. See if you can preview a few photos and that it works in preview - If it does NOT I cannot help you here.
4) If the Camera Works in Preview mode then press the Shooting/Preview button to put it back into "Take Photo Mode".
5) There can be a delay but it starts up without the lens error.
6) Make sure the ZOOM IN and OUT works and in most cases if the lens operates then you can take a photo. If the Zoom in and Out does not work you have a jammed lens.
7) If the LENS is Jammed AND it is OUT of warranty you 'might' want to tap the lens barrel against your palm. I have found when you remove the battery you can gently tap the lens into telephoto mode by tapping the back of lens assembly into your palm.
May 28, 2008 | Nikon COOLPIX S10 Digital Camera
Delayed preview image
Sounds like you accidentally pressed the DISP button on the back (it manually turns the LCD screen on and off to save batteries). Turn the camera on and press the DISP button once. Hopefully that should fix it.
Mar 24, 2008 | Canon PowerShot A550 Digital Camera
Toshiba Satellite A205-S4607 Notebook PC Logo
118 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
