My printer went to default and I dont know how to get it back to where I can copy pictures again off of the internet.
My printer does not print it goes direct to easy share by kodak i dont know how to stop this and get it back to printing regularly F300 printer joanwantschange@yahoo.com
In the ''printers and faxes' dialog box in 'control panel', "right click" your F300 printer and click on "set as default"
Please rate solution
Posted on Apr 17, 2009
When copying,it prints a half page only
Try to set your printer back to Factory Default Settings:
  1. Press the Copy button on the operator panel.
  2. Press the Options button until SET DEFAULTS: Use Factory is displayed, then press Select.
  3. Enter your preferred Language, Date, Time, etc.
  4. Try to make a copy again.
Jul 24, 2011 | Lexmark X4270 All-In-One InkJet Printer
My Brother HL 1440 has a copy 1 and copy 2. How should I get back to the original printer and delete these copies? How did I get these copies to begin with? Now to get anything to print I have to select...
Need a bit of clarification on this...
So when you try to print something you see more than one printer (Brother Copy 1 and copy 2)??
Seems like it's listed more than once in your printers folder. Depending on your operating system, you need to find your printers (windows it is in control panel, under printers). Simply delete the unwanted ones, right click the one you want as default and select set as my default printer (again in windows).
Hope this helps
D
Oct 22, 2010 | Brother HL 1440 Laser Printer
When I press print, it defaults to the mp tray feed. It shows in the screen that the default is the tray 1, but it goes to the the MP tray instead.. how do i fix this?
While I'm not familiar with the T632, I have a C782 with the same problem. I, too, tried changing the Paper Source settings with no help. Instead, I went to "Settings" then "Copy Settings" and then changed "Copy to Source" option to the value of "AutoSize Match". This fixed both our copy and print problem. If your printer does not double as a copier and does not have this option then I don't know what to do.
Feb 19, 2010 | Lexmark T632 Laser Printer
No power on my Lexmark X8350
That's the same printer I have.
First, make sure the blue "copy" button is lit. Printing is done there.
Then, go to the circle with the checkmark in it and hit the menu, and arrow down to copy papy size and make sure it says "letter".
Click start on your computer, then click control panel, then printers, and make sure Lexmark 8300 series is the default printer and has a green checkmark in a circle.
If all these things are right, you should be able to print a test page and the computer should work fine.
If any one of them are wrong they must be corrected. If you need help on any one of those please write back.
Sirwriter
May 14, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Can not get my Cannon MP470 printer to print in color again _
TRY GOING INTO YOUR INK SETTINGS AND TELLING THE PRINTER THAT BOTH CARTRIDGES ARE FULL IF THAT DOESN'T HELP GO INTO YOUR PRINTER VIA CONTROL PANEL AND MAKE SURE ALL SETTINS ARE BACK TO DEFAULT .
May 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Help please
When printing you should go to the properties dialog box and check the quality setting that your printer defaults to. You'll probably find options to print either custom, fast, standard or high - you'll probably also be give a choice of paper type to print to - photo, etc. You may or may not be able to make these settings your defaults from now on but most likely you will have to set these at the beginning of your print sessions.
Feb 22, 2009 | HP PSC 1350 All-In-One Thermal Printer
My printer,scanner and copier started behaving funny when i installed Vista Business. it prints a countless number of pages when a command is given.
Hi again,
I sugest that you download a new driver from here: - you have to join them in order to get the driver, but its free. NOTE, you problem might bee that you have installed a Vista32 driver on a Vista64 computer, please be sure to download and install the right one.
regards /Teis
Dec 29, 2008 | Office Equipment & Supplies
Canon printer MP390
My MP390 wasn't printing black, despite the cartridge(s) being new. I reinstalled CD and then it worked. The next time, it did not print again. I, then d/l driver from online...same thing. worked once and then not. Also, it doesn't copy anything in black
Dec 16, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
k24674
jasbo
jasbo
