Question about Brother GX-6750 Typewriter
I can not figure out why it won't type
The wheel does not spin and I am attempting to find the lock lever ?
  • sunkissd Sep 16, 2007
    http://www.brother.ca/en/products/pdf/ma... I found this manual for myself but it has not helped due to I think the key hammer motor is dead.
    Problem Solver:
  • 19 Answers
Could be the print hammer selenoid is stuck if the print hammer does not fire at all. It shoild fire whether there is no ribbon or print-wheel installed. Look around for any loose cables but failing that your only option is to go to a repair shop.
Posted on Oct 20, 2007
Tilt lever on steering column is not staying in place, so the steering wheel slowly move up to block my view. I know its a simple fix, but I need some kind of direction on how to remove it probably
I don' t think so.
Not a simple fix.
The tilt lever is down underneath the horn button, which is part of the air bag system which is on top of the steering wheel, which is on top of the tilt lever.
All this is a big job to deal with.
If this were my car, I think I would figure out a way to lock that lever into the locked position.
That would likely take some creativity.
Do you know someone creative?
Fixing it will likely require removing the steering wheel.
God bless your efforts.
May 16, 2016 | Cars & Trucks
Riding mower won't move forward or reverse
WHAT MAKE AND MODEL MOWER? YES...YOU EASILY COULD HAVE BROKEN THE AXLE!
SEE IF EACH WHEEL WILL SPIN INDEPENDENTLY OF ONE ANOTHER IN BOTH DIRECTIONS. ALSO, SOME MOWERS HAVE A ENGAGE/DISENGAGE TRANS LEVER (USUALLY PULLS IN AND OUT AND LOCKS WITH A CLEVIS PIN RETAINER)
Jul 26, 2013 | Garden
Steering wheel won't lock, key won't come out
If the ignition normally only locks with the vehicle in park position, then check the switch on the gear lever mechanism is working.
If not, then you'll have to jiggle and wiggle that key out or replace the ignition lock.
Nov 10, 2012 | Volkswagen Cars & Trucks
Ignition stuck key won't turn to start car!
Gear shift is not totally in the park position - had the same problem with a 2011 Acura TL - a rubber band kept the gear shift lever from totally seating in the park position.
Oct 02, 2012 | 2003 Ford Focus
Rear wheels won't move chain just spins
I posted a solution to this previously, please check it out.
Aug 27, 2012 | Razor MX650 Electric DirtBike
1987cadallic deville steeringwheel
Usually, vehicles with tilt adjust steering, have a small lever just under the steering wheel column. Pulling this lever out, unlocks the wheel. Pushing lever back in, locks the wheel.
Have a look for a lever of this type and once you find it, have your Dad hold the steering wheel at his preferred position, then push the locking lever back up, to lock the wheel in place.
Let me know if you resolve this.....
Cheers,
Dec 28, 2011 | 1987 Cadillac DeVille
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
Steering wheel was turned in process to locate battery prior to knowing that positive and negative prongs where located under the hood for more convient jump start. after recieving an intional charge and...
The ignition key and lock cylinder operate a gear and lever type of mechanism within the steering column. If the gear jumps out by one tooth, or has been assembled incorrectly, it will cause the steering wheel to remain locked and the push rod that activates the ignition switch (located near the bottom of the column) will not function correctly. This can be very tricky to solve, and should be serviced by an experienced technician.
Sep 27, 2008 | 2001 Chrysler Concorde
Brother ML100 Typewriter:All of the sudden, it just won't type. It seems the 'hammer' doesn't hit the daisywheel. We've replaced the daisywheel, corrective tape, ribbon and still it goes through the...
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Nov 14, 2007 | Office Equipment & Supplies
Brother GX-6750 Typewriter Logo
161 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
