Question about Grundfos RCP-96 Recirculation Pump for Tankless Water Heaters
Does grundfos rcp96 pump work with bosch 2400 eo tankless heater?
I am interested in a grundfos rcp96 pump. My questions are does it work with my bosch 2400 eo aqua star tankless water heater, and does it requires a dedicated pipe line for the warm water to be pumped back to the heater for recycling? What are the installation requirement for this pump?
Would you recommend any recir pump for my bosch 2400 heater for ease of installation, price economy, and reasonable performance with a timer.
Thanks for your help. Pat
  • Anonymous Mar 18, 2014
    Model#75232 Grundfos recirc pump [elec]. Sinks close to heater ok...far bad, Pump seems very hot to touch.
    recent diode change and drain.
    Problem Solver:
  • 11 Answers
What is your reason to have a recirc line on your water heater does the heater sit to far away from a certain fixture? If you put a pump on your tankless waterheater then your heater will continually fire till the call for hot water is stopped. Yes you normally do need a seperate line installed for a recirc line usually from the water heater to the farthest fixture away. If your problem is taking to long to get hot water then I suggest installing a second heater closer to problem area.
Posted on May 25, 2009
How do i gas heater gwh 2400 ctd efs Lp
Stupid me but could you be a little bit literate in asking a question.
My dog write better questions that I can understand than this scribbling.
A GWH 2400 is the little brother of the GWH 2700 much like the 635ES. If you have an LP model be sure to use the overpressure protection valve supplied by Bosch as overpressure in LP (above 10-14" WC) can completely destroy this unit.
And you can use a TPR or PRV for 170,000+BTU being sure you get a House Pressure valve of 60-80-100 PSI+ and not the boiler PRV for 30 PSI
Beyond that your questions above states nothing recognizable as a technical question
Oct 19, 2014 | Bosch & Tankless LP Hot Water Heater
I've got the Bosch AE 9.5 tankless water heater.
1) Cheapest and most reliable solution: Install tank-type electric water heater from local box store for $250. Get store coupons, offer 10% off store price. Repairs are made same day with generic off-the-shelf parts.
http://waterheatertimer.org/pdf/How-to-install-electric-water-heater.pdf
2) Install grundfo water pressure boosting pump.
http://www.ronhazelton.com/projects/how_to_increase_water_pressure_in_your_home
http://waterheatertimer.org/How-to-solder-pipes.html
3) Remove areators and low flow shower heads, Maintain unit as shown in product manual: Delime tankless unit yearly, Clean water filter monthly.
4) Call city and report low pressure and report issue as fire hazard, move to different apartment. Call apartment complex and ask why they didn't read flow requirements for tankless before installing tankless.
5) Call Bosch 866-330-2729 and complain that nobody read the flow requirement or tested local water flow before installing tankless.
Dec 30, 2012 | Water Heaters
I have a Bosch GWH 2400 CTD EFS NG tankless water heater. It has been installed on operating for over a year in the last several days it has an error code A3. The first two times I was able to reset it....
Call qualified service technician, and ask that person questions about maintenance and tips.
Then keep service technician number in rolodex-wallet.
Resourceful do-it-yourselfer will find following links handy.
Tankless are maintenance heavy, and Bosch and Rheem etc say to call service technician for recurring problems. Especially when short-hand troubleshoot section doesn't solve problem.
People spend years learning how to service tankless.
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
BOSCH error codes online:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Bosch manuals:
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx
Bosch problems at Fixya:
Open following links and read about tankless problems to understand the field and glean useful information.
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Post question on pro water heater forum: This is where I go to catch up on latest info in always-evolving water heater industry.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Pay for an answer at fixya:
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 18, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch manuals:
Mar 17, 2011 | Bosch & Tankless LP Hot Water Heater
Will the Grundfos RCP-96 model work with my Rinnai tankless heater model # C85e-1?
Grundfos RCP-96 has Flow range: 0 - 27.5 U.S. GPM
According to Amazon spec sheet:
http://www.amazon.com/Grundfos-RCP-96-UP515-55SFC-Recirculator-Timer/dp/B00128BJAO
Most tankless require .4 GPM to start burner and .25 GPM to maintain burner
Rinnai does not show C85e-1 so you will have to consult your manual to see minimum water flow requirement.
http://www.rinnai.us/tankless-water-heater/
Sample manual from Rainnai mentions 'minimum flow rate' several times but doesn't give specific number. Yet promotion blurb on page 1 says "Ultra operates at a lower minimum flow rate."
http://www.rinnai.us/documentation/downloads/U290-665x0200_Condensing_Manual_EN_FR_1-2010.pdf
Another rinnai manual mentions flow rate several times in troubleshoot section yet fails to define what that rate is:
http://www.rinnai.us/documentation/downloads/U287-1833_VB_Series_R75LSi_R94LSi_R98LSi_Manual_EN_FR_EN_FR.pdf
It might seem that tankless promoters are CTA by failing to mention specific flow rate numbers.
I think tankless promotion is a definite overachiever, and vague flow rate is one tiny example.
It proves the necessity of reading whole manual and asking questions before buying a tankless.
There's another factor to consider:
All performance numbers are based on new products in ideal circumstance, and not based on a 4 year old product located in your home.
Your flow rate may vary, especially over time, and especially if water in your area is not crystal clear, and you are not diligent with correct water softener and filter.
Many factors can affect flow rates: water pressure, number of elbows, clogs in the line, sediment, size of pipe, aireators, water-saving shower heads, local water conservation policies, water well pressure, MUD district pressure issues, your home located near end of a water main, etc.
Read tankless efficiency vrs water softener
http://waterheatertimer.org/Battelle_Final_Report.pdf
Image of tankless parts vrs tank parts
http://waterheatertimer.org/images/Compare-water-heater-parts.jpg
Bradford White tankless vrs tank side by side
Lime scale does not flush out of tankless
Tankless must have water conditions with less than 11 grains hardness
"Savings falls far short of a payback," 'without comparing service costs'
http://www.pmengineer.com/Articles/Cover_Story/8cf9e86f7c298010VgnVCM100000f932a8c0____
geno_3245_197.jpg Sediment clogs tankless pressure sensor without softener.
Dec 28, 2010 | Grundfos RCP-96 Recirculation Pump for...
I have Bosch 2400 ES NG indoor model, it stop working today. it is under warranty, do you know who carries parts, also certified technician to do a house calls.
Sorry to read about your problem, I hope this helps you out.
bosch direct is the only way and contact bosch for service
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | Bosch & Tankless LP Hot Water Heater
Grundfos submersible well pump with Grundfos CU301 control. Control box shows no contact to pump. What is the problem or problems?
Grundfos is a p. o. s. I have a new system cu 301 and I have had to get it repaired twice by Fogle Pump and Supply. These guys are real rip of artists in Washington State and should be reported to the BBB. Dont Use Fogle if you need a well
Sep 15, 2010 | Grundfos RCP-96 Recirculation Pump for...
I have a newly installed Bosch hot water heater. After installing, it seemed to be working fine. It is in a small weekly rental unit. If anything, the unit is over-sized for the demand. Now that it is...
these units need lots of flow to start and run. Set the temp on the unit lower and the people in the shower will have to use more hot and less cold which will make the unit more stable.
Jun 01, 2010 | Bosch & Tankless LP Hot Water Heater
Bosch on demand tankless water heater gwh 2400 E LP error code "
BOSH AQ 250 On demand propane water heater ran out of propane, got gas now, but get EC flashing on the display and the unit won't fire? Lost manual, any suggestions. Thanks, Jim
Jan 06, 2010 | Bosch AquaStar 2400ES-NG
Wilo 3speed recirt pump for my wood stove
I wasn't aware that you would put a citculating pump on a tankless water heater, but as long as the arrow goes in the direction of the water flow that is how it needs to be,, putting a circulator on a tankless kind of goes against what it is for, the tankless will never shut off and once it is on how will it ever satisfy itself to shut down?
May 26, 2009 | Grundfos RCP-96 Recirculation Pump for...
Grundfos RCP-96 Recirculation Pump for Tankless Water Heaters Logo
404 people viewed this question
Top Grundfos Water Heaters Experts
jdthefixer
David Spradling
David Spradling
Are you a Grundfos Water Heater Expert? Answer questions, earn points and help others
