Question about Acer Aspire 4315 Notebook
Audio driver my laptop doesnot match with CD definition
MY SYSTEM SOUND DOESNOT COME ALTHOUGH I HAVE INSTALLED AUDIO DRIVER . CAN YOU HELP ME ?
hello sudeep,
First check in "Device Manager" to see if there is a red x, or an yellow exclamation mark next to your audio hardware.
If there are no issues in device manager, uninstall the audio driver, and try once more. http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+865+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D865GVHZ
If problem persists after installing the audio drivers, try a bootable cd such as Knoppix.
http://www.knopper.net/knoppix/index-en.html This is a linux boot cd, but they tend to be the most strait forward. After you have booted to the live cd you can play a media file, or bring up a website such as youtube to see if your audio works. If it does work then it is definitely an driver issue, if however it doesnt work then this is a hardware issue. Luckily sound cards are inexpensive, and easy to install.
Good luck
Aug 16, 2011 | Intel D865GVHZ Motherboard
There is a yellow question mark on my modem high definition audio bus
You need the correct driver for that device.
What Operating System does your computer have?
Mar 01, 2011 | Dell Inspiron 1501 Notebook
When i installed realtek high definition audio driver in my acer aspire 4520 os xp i found a modem device on high definition audio bus. the sound not working
Try downloading the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Feb 23, 2011 | Acer Aspire 4520-5950 Laptop
Audio device on high definition audio bus
Download the drivers from the Acer WEB site.Make sure you select the model of your laptop and the XP or Vista version ofthe drivers you that require and it matches the Windows version that isinstalled on your laptop. Use this link to get to the Acer support: -
Feb 17, 2011 | Acer Aspire 4720 Notebook
Realtek audio driver doesn't intall
just download or update ur Realtek High Definition Audio codec ALC268
Jan 03, 2009 | Acer Aspire 4720 Notebook
Driver problem in compaq presario c700 laptop
Try connecting the headphone properly.
Check if its properly inserted.
Go for windows update............... and then check if the problem is gone.
If all the above doesnot works I think there is a connection between the metals inside your headphone portal, ans as soon as you insert the jack it gets connected and you can hear sounds from both the sources.
Thank You.
Nov 13, 2008 | Microsoft Windows XP Professional With...
My system doesnot play system sound
Check the manufacturer website for driver support. If the site has no downloads, google the manufacturer name, device and the word driver to search for updates. (i.e.- dell audio driver)
Oct 07, 2008 | Computers & Internet
I want audio output drivers
First of all, let me tell you that the DV1000 series Notebooks are divided into two types..
One type is shipped with Conexant AC-Link Audio card and the other models are shipped with Conexant High Definition Audio card.
So, if your Notebook is shipped with AC-Link audio card, you will not be able to install the High Definit audio drivers and vice versa.
So, first, try downloading and installing the Conexant AC-Link Audio card Drivers for your Notebook from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32272.exe
Save the file on the Desktop or My Documents folder and double click once the download is completed to installs the drivers.
However, if you are unable to install the above Drivers, we can come to a conclusion that the Notebook is installed with High Definition Audio and to install this drivers, we need to install the Microsoft Universal Audio Architecture(UAA) drivers before installing the Audio Drivers.
Download the Microsoft UAA Drivers for your Notebook from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Once the download and installation is completed, restart the Notebook and now, you can download and install the Conexant High Definition Audio drivers from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32864.exe
Restart the Notebook and you should be able to use the notebook normally.
Hope this helps...
Sep 02, 2008 | HP Pavilion dv1000 Notebook
Acer Aspire 4315 Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
