Question about Dishwashers
How do remove the sprayer arm?
How do you remove the spray arm on whrillpool du 840 swkq i need to replace the pump
  • mathenywasja Apr 16, 2009
    that was not how my spray arm came off theer was one large nut holding it to the pump ihave it off now thank you
  • 10,515 Answers
Hi mathenywasja,
   For removal of spray follow :-
http://www.acmehowto.com/howto/appliance/dishwasher/check/sprayarm.php
http://www.partselect.com/repair.aspx?appliance=dishwasher∂=remove-spray-arms
To replace pump, procedure would be :-
The pump is not difficult to remove and replace. If you have a little bit of mechanical ability, you can replace the pump easily. You can find the pump by following the drain line into the bottom of the dishwasher. The drain line connects to the pump.
The pump will come out fairly easily by removing a couple of fasteners. Make sure you find an exact replacement part or you could be in for a world of trouble.
Thanks for using Fixya.
Do rate the solution.
Posted on Apr 16, 2009
  • taran_2005
    taran_2005 Apr 16, 2009
    1. Open dishwasher door and remove lower rack.
    2. Pull upper rack partially forward and detach the water delivery system from the tub anchor points (2 clips on stainless models; 2 screws on plastic models). Removal of the upper rack may ease removal of the water delivery system, but is not necessary.
    3. At rear of pump, grasp the water delivery system and rotate clockwise while lifting upward. When rotation stops, lift the lower spray arm until it is clear of the pump and pull forward. The spray arm assembly and water delivery system should now be free for removal.
    If you want to just remove the lower spray arm, just hold onto the spray arm and turn the center hub clockwise until the arm is free. Depending on how tight it is, you may need to use pliers.
    Thanks.
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
My Kenmore UltraQuiet 8269644 has been performing poorly. Have cleaned various filters and traps. The spray bars tend to clog with food refuse and now it is leaving a white film on dishes - either...
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Also, dishwasher detergents need HOT water, so be certain the water is at 140 degrees. Make sure your detergent is fresh!
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 12, 2011 | Dishwashers
The top sprayer is not spraying any water and the middle sprayer has water except it does not have enough pressure of water to spin around the sprayers. What do I need to do to fix the problem
All sprayed water comes from the pump located at the lower deck. Remove all parts from the lower spray assembly (note position and orientation of each part) down to the deck. There should be a large filter screen at the bottom that commonly becomes plugged with food and hard water deposits. Soak the screen in a mixture of hot water, white vinegar, and dish detergent for an hour or two until the deposits come free. Check around the pump area and the deck openings for any debris plugging. Reassemble in reverse order, but check all three spray arms for spray hole plugging or split seams. Hope this helps!
Jun 11, 2010 | Dishwashers
Top spray arms dont work.
Most likely you have debris blocking the holes in the spray arms. The spray arms can be removed and cleaned out in your sink. (blocked holes in the lower spray arm arm almost impossible to clean out)
Jun 05, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Bottom Sprayer not spraying. does not look blocked
1)wash arm not spraying(or)rinse not spraying?
wash arm
1)remove the wash arm
2)switch on the machine all blockaged removed automatically.(remove the wash arm).
rinse arm
1)check any scaling in the boiler tank.
2)clean the boiler tank.
3)clean the rinse arm.
Jan 07, 2010 | Dishwashers
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
Spray arms do not turn. water to them but not
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 23, 2009 | Bosch 24 in. SGS43C12 Classixx...
I have an equator PLS600 and I can't seem to get it to work. I have tried the WikiFix to help a stalled dishwasher, by adding water and vinegar. When I put on the wash cycle it does not run. Even with the...
Give the spray arm a spin to make sure it rotates. It should spin freely. If not, remove plastic spray arm clip, flip it over, replace it, and try again. Make sure holes in the spray arm are clear of debris. Spray arm must be clean for it to spin. If spray arm does spin freely, remove spray arm clip, spray arm and the post assy (the thing the spray arm attaches to). Try your WikiFix again. This time add baking soda to the hole the post assy came from. Top it off with white vinegar. Leave it overnight. In the morning, stick your finger down the hole where the spray arm assy sat. You should feel a plastic thing. This is a propeller attached to the recirculation pump. You need to free it up. Get that thing moving with your pinky or a chopstick or whatever. Try the machine without the spray arm. You should get water blasting up from the hole. Reassemble the spray arm.
Nov 26, 2008 | Equator 20 in. PLS600 Free-Standing...
Dishwashers Logo
569 people viewed this question
Top Dishwashers Experts
