Question about Maxtor OneTouch II Hard Drive
Disappears from system
This drive is connected by firewire to a Dell XPS. It has functioned well for about 18 mos. Suddenly the password protected sign on window failed to appear. The blue light still glows. Without the sign on window I cannot access the drive.
  • 67 Answers
Re: Disappears from system
Right click my computer click hardware click device manager look hard drive
Posted on Sep 19, 2007
0 characters
3 Points
How do I use the password protection?
Your questions isn't too specific but I hope this helps
There are several ways to incorporate password protection. You can set the computer to require a boot up password in the computer BIOS. You have to enter the computer BIOS as soon as you turn it on; with a Dell press [F2], with HP press [Esc] and select system configuration. In the BIOS you can set the BIOS Administrator password - controls the ability to change BIOS settings, the computer boot password - when enabled it requires the user to enter the bootup password before the computer will boot, and set the hard drive access password - controls the users ability to access a hard drive.
The next level of password protection is at the operating system level - account access levels, privilege levels, and passwords. Dependent of operating system you can also set hard drive encryption
Oct 28, 2014 | Maxell MAXDATA 503802 - FLIX8G HIGH-SPEED...
I have a new Dell xps 18 and was wondering if the windows logo on the bezel is supposed to give a swooshing sound when touching it.. this didn't happen yesterday when I bought it...
Windows sounds are optional items that can be turned on and off in the Control Panel. That swooshing sound is one of those options, so this can be normal depending on how things are set up. If it did not happen yesterday but does today, then that could be because yesterday the computer had not fully "unpacked" itself from the "new from factory" state but has completed that process by now or it could be that you unknowingly changed an option or installed a program that modified the Windows sound configuration to include this sound. In any case, it is nothing that is causing harm and can be turned off if you wish by going into the Control Panel.
Sep 30, 2014 | Dell Xps 18 18.4" Portable Touch-screen...
What is the master password for Dell latitude E5510?
Just call the dell service centre, they know most about their systems and we can't know your passwords
May 04, 2014 | Dell Latitude - E5510 Laptop Computer...
Have a dell latitude D620 that is password protected in such a way as to prevent even the F2 and F12 keys to function. Can you supply a way around this please
You may have a USB keyboard that is not recognized by the BIOS on powerup, but is later recognized by Windows when that starts running. Try connecting a keyboard with a PS2 connector, enter F2 on startup and set the BIOS to enable USB devices in BIOS. If this still doesn't work, then keep a PS2 keyboard around in case you ever need to activate F2 or F12.
Oct 24, 2013 | System Integration Business 160gb for Dell...
How do I bypass the BIOS password on a Dell M1330 laptop?
try removing the cmos battery for about 10 minutes then replace
you can watch how to do it here Dell XPS M1330 ' CMOS Battery Replacement on youtube
Apr 27, 2012 | Dell Hard Drives
I have just purchased a 1.5 Tb Ext HDD which I wish to use on my MAC computer Time Machine. My previous Ext HDD was a 5009 Gb drive which I want to remove from the house to separate the two completely. ...
Thank you for your question, the process will involve terminal and I will link a video demonstrating how to do that. They gentleman in the video has a British accent from the sound of it so there might a bit of language difference. Everything else seems pretty self explanatory. Good luck!
Mar 08, 2011 | Apple Iomega 500GB UltraMax eSATA/FireWire...
My computer doesn't recognize my Acomdata 250 Gb Hard drive (HD). The computer pops a balloon saying that it could run faster with a hi-speed 2.0 port. I own a dell Xps m1210, the installation cd that...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Nov 27, 2010 | Acomdata 250GB External Firewire HD 250 GB...
Problem when connected to the e-sata port of two dif. computers
I think we a re talking about SMART technology, that is disk is telling you that something's wrong. If you have a guarantee, return it to reseller and ask for another one.
Jan 15, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Maxtor OneTouch II Hard Drive Logo
128 people viewed this question
Top Maxtor Hard Drives Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Maxtor Hard Drive Expert? Answer questions, earn points and help others
