Question about Proview PL913B 19" Flat Panel LCD Monitor
Proview monitor won't keep the screen on
When I turn my monitor on it comes on for a few seconds and then the screen goes black but the on green light stays steady and lit..what would be the problem here? If I turn it off then turn it on again I get a picture for about two seconds..then does what I just said.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Bzinbby1, Hi, I think I know what's wrong. In fact I already know what's wrong! But I want you to do one test to let me know how bad it really is! Here is the test. I want you to reconnect your Proview to an already fully booted "KNOWN GOOD" pc with WIN DESKTOP showing. Then and only then power up the Proview and hold a good, bright flashlight 2 inches from the lcd screen after the screen goes to BLACK! Even though the screen appears BLACK, can you still see the WIN Desktop if you hold the flashlight at different angles???? Get back to me with results of test. I will then tell you what options are open to you as a consumer whose screen is now dark and lifeless. I'm louie12fix on fixya or lmistyrel@ aol.com
Posted on Apr 16, 2009
  • 4 Answers
If you can see the pixels like he says, the backlight's gone - which is pretty easy to fix. Look at the capacitors first, if any of them look oddly bulgy, chances are that's done it. You can also try finding fuses and testing them for resistance - if it stays at 1 then the fuse is bad. Check for dry joints (where the solder hasn't quite melted on to the components properly) and burnt marks in case something's overheated.
If you have any other monitors, it's worth piggy-backing them, so that the monitor you're fixing is powering the screen and a different monitor is powering the backlights. They will be connected to the board by pink cables, most likely, and there'll be two or four of them - there's two long fluorescent tubes going along the top and bottom of the monitor. If the tubes are ok, then the board they're connected to is bad, whether by capacitors, burnt bits, or a popped fuse.
Posted on Jul 08, 2009
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Proview Monitor Blank display after 3 seconds issue
First place to look will be the power supply section, look for bad caps (bulging tops or bottom seals), the post back what you see so we can guide you further for direction such as voltage checking, see example of failed monitors due to bead caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 28, 2010
paulbtorrent
  • 34 Answers
SOURCE: ACER AL1914 LCD Monitor goes black but green light stays on
The monitor is doing a self test a finding an error.
The lcd has three parts, the screen plate(windows)/the logic(vga)/the inverter(power plug). Parts that go are the backlight ccfl's, behind the plate, and parts of the inverter, ie capacitors, all three take a bit of power from the inverter. The self test check that all the lights are ok and the inverter is ok, else it switchs off, ie if 3/4 light work it will switch off(my own case), hence the on chech error then off, However sometime there are stages of on/off ie on/ but no screen display, if that is the case the following may be of help...if you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new one do go burst! you have to laugh really, what next , a new on/off button, as you work though the whole inverter mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going
to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.http://www.lcdparts.net/howto/troubleshooting/LaptopCCFL1.aspx OR MONITOR
Posted on Feb 08, 2010
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor come on for a few seconds then goes black,green signal light stay on green. can you help
the monitor may be losing the back lite. take a flash light or bright light and shine it at the screen after it goes black. can you see a faint picture? if so the back lite has failed. usually the cost of replacement exceeds the cost of a new monitor but there are a couple of web sites that detail the replacement of the "ccfl" cold cathode flouresecent light.
Apr 27, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
Proview Monitor PL926 Wbi The power indicator
Repair estimate will be according to problem.
Nov 13, 2009 | Proview PL926WBi 19" LCD Monitor
MY screen will stay on for 30 seconds, then goes black.
you Screen has a Soildation problem take it to near by electrition he will resolidate your screen and it will then work fine..
Aug 27, 2009 | Proview PL 566s 15" Flat Panel LCD Monitor
Monitor only stays on a few seconds
You have a burned out Backlight Fluorescent Bulb.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
Faulty monitor
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
May 11, 2007 | Proview XL370B (Black) 17 in. Flat Panel...
Proview PL913B 19" Flat Panel LCD Monitor Logo
1,059 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Diego Zenizo
Diego Zenizo
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
