Question about Digital Blue EasyShare MD1063 Digital Camera
I have kodak md1063 memory card will not format
Have used memory card ok but sent camera back to kodak as lens would not retract this was repaired but then memory card would not format.
  • andrew whitmore Apr 28, 2009
    what a waste of time that was
    Genius:
  • 1,234 Answers
Hi there
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    Camera shuts down when 'zoom lens' is used.
    Hi there please follow the steps and let me know the result.
    1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
    2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
    3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
    4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
    5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
    Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
    back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
    in not done the press both Menu & self time key for 2 - 4 sec.
    Jun 10, 2010 | Kodak EasyShare C913 Digital Camera
    THE LEN IS STUCK ON EXTENDED POSITION AND WILL NOT RETRACT TO THE OFF POSITION? BATTERY WAS FULLY CHARGE.
    If no power on the camera:
    Here are the steps:
    1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
    2. Clean the battery contacts.
    a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
    b. Reinstall the battery/batteries into your camera
    3. Turn on your camera without the memory card.
    If there is power on the camera, bnut the lens is stuck:
    This is a lens error. KODAK suggests a repair for this fault.
    However due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
    Contact KODAK:
    http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
    Dec 10, 2009 | Kodak EasyShare DX7630 Digital Camera
    My camera will not stay on is off and stuck with lens out
    If the lens doesn't retract on most digital camera the camera also will not turn ON. It is connection or wiring between camera power and camera lens.
    What Kodak Rep will ask you to do are:
    1. Remove the battery and the memory card of the camera
    2. Check if your using a recommended battery and if its new or fully charge. batteries for Z1275 are Ni-MH rechargeable; CRV3 Lithium; 2AA Lithium
    3. Insert the batteries back in the camera in correctly
    4. Set the camera in Auto mode (its the camera icon on the dialing mode of the camera)
    5. Try to turn it ON
    If still will not turn ON and the lens will not retract
    6. If your using a rechargeable battery Kodak Rep will ask you to charge the battery until its fully charge.
    If your using a disposable battery they will ask you to try to use a new battery out from the box.
    After all those steps still the camera failed to work, it will be send for repair. The number of the Kodak support line is 1 800 235 6325 (23KODAK)
    Nov 20, 2009 | Kodak EasyShare Z1275 Digital Camera
    Lens doesn't retract
    This might be a lens fault and a repair is recommended.
    If it also switch off when not retracting then it could also be a no power issue.
    You could try following:
    Make sure that you are installing a fresh/ full charge battery
    Remove the memory card and the battery
    Clean the metal contacts on the battery using a clean cloth
    Use the camera w/o the memory card
    Pls test with an alt. batt.
    If you do not have access to a dif. battery.
    Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
    Contact KODAK:
    Oct 11, 2009 | Kodak EasyShare V1003 Digital Camera
    The lens of my kodak easyshare V1003 is not working when i turned it on....
    Please clarify you issue. Does the lens stick? Does is refuse to retract? does it switch off?
    If it switches off Try the following if any other listed faults a repair is needed:
    Contact KODAK:
    Aug 30, 2009 | Kodak EasyShare V1003 Digital Camera
    CAMERA TURNS ON THE LENS COMES OUT THEN IT TURNS RIGHT BACK OFF AND LENS RETRACTS
    Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
    http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
    Jul 17, 2009 | Kodak EasyShare Z712 Digital Camera
    Doesnt stay on, tried new battery, it just switches off
    Get Kodak or SanDisk SDHC 2 or 4 GB memory card.
    Format Memory Card.
    Make sure it is charged 3 hours minimum.
    Vitally
    Apr 27, 2009 | Kodak EASYSHARE M1063 Digital Camera
    Kodak easyshare dx4530 turns on then off
    Hi there.
    90 percent of the time when the lens malfunctions, it's due to grit or dirt in the lens mechanism. If you stored your camera in a camera bag, while you used the other camera, that could be your problem. Camera bags are great for holding dirt so it can get in your camera.
    When the lens can't move, it may cause the camera to shut down. To fix this, use an air compressor. Put the nozzle to the camera and blow air into the space between the camera and the lens. Blow it out real good and try it again. You may have to repeat the process a couple of times. Hope this helps.
    Rob
    Mar 03, 2009 | Kodak EasyShare DX4530 Digital Camera
    Camera Kodak md1063.
    This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. Before you purchase new batteries, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
    Jan 02, 2009 | Digital Blue EasyShare MD1063 Digital...
    On my kodak camera the lens is stuck
    Is there power on the unit? Or does it switch off and then not retract?
    If lens issue a repair is needed.
    If power issue:
    Contact KODAK:
    Oct 12, 2008 | Kodak Cameras
    Digital Blue EasyShare MD1063 Digital Camera Logo
    70 people viewed this question
    Top Digital Blue Cameras Experts
    Steve
    Are you a Digital Blue Camera Expert? Answer questions, earn points and help others
