Question about Water Heaters
Heater light flashes but heat will not come on on its own
I con turn it on manualy when i turn the pump on but if the tub sits for a few days the tempurature will drop way down
I have just filled my hot tub after cleaning it out
all the pumps work but it will not start to heat up.
the heater light is flashing and I am sure it should just be a permanent light on.
any ideas
Posted on Oct 31, 2009
  • 332 Answers
Sounds like the heating element is going bad, have someone come out and change it, it will be fine
Posted on Jun 04, 2009
I can get hot water but central heating will not come on. The radiator sign on the boiler is flashing all the time
there might be a problem. flashing lights meaning there is something wrong in either wiring or heating coil. some are equiped with manualy reset system. or some solinoid or contactor or a motorized valve. scaled water sensor or stuck float swithes.
Oct 25, 2016 | Water Water Heaters
Power vent 2 41vrp50n
Copy following links for troubleshoot by type of gas control valve, error codes and diy resources:
2 flashes might be pressure switch failure:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pressure
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Rheem does not post service manuals, as consequence almost all water heater questions on fixya are about Rheem products. However other companies use same gas control, and have service manuals available that might assist.
Call for service technician.
Gene
h
Sep 11, 2013 | Water Heaters
Heater
Water heater can be added to any incoming water line, either on hot or cold.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Under-counter water heater located near tub will supply hot water just like ordinary household water heater. But it will not reheat water that circulates inside the spa tub.
Otherwise, a spa heater is made with electric element that can work with 120V or 240V. Water from tub circulates through tank that holds element. Element must be fully immersed in water.
To retrofit spa tub with this heater would require cutting water line near pump, running both ends of water line into tank with element.
Then of course you would need to retrofit adjustable thermostat to control when element is on. And integrate element operation into air control switch at tub that can override thermostat so element is not heating when tub is not in use.
Unless there is a pre-packaged kit to retrofit heater, I think adding heater would be difficult.
Jun 05, 2013 | Maax Crescendo - 100085-000 Bathtub
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Tankless on demand water heater.
Tankless water heaters normally take a little longer than a regular heater to provide hot water because they have to start and get warmed up. I'm guessing the heater uses a pilot light and that the short amount of hot water when you turn on the tap is hot because when the water is sitting still in the heater the heat from the pilot light is enough to get it hot. The tub faucet will get hot a lot faster than the shower because it lets a lot more water through and empties out the pipes faster than the shower. You could probably speed things up by letting the tub faucet run on completely hot for like 10-15 seconds and then turning on the shower.
Oct 24, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
Infiniti hot tub reads HL
the pump just pumps, do you have a heater it would be about 2inch in diameter adn in line with a cord comming off of it that plugs in seperate from the pump that is the heater,
May 24, 2009 | Maax Infiniti - 100055
My alpha cb24x combi boiler keeps blowing the main fuse,even when its not on,this can happen in 2mins or 2 days after i redo the fuse using 15 amp wire, why is this happening ?
a short circuit most likely on the pump or another winding, fan or gas valve. start with shutting off the power and pocketing the fuse untill ur done . dissconnect the pump supply and fit terminal blocks to make them safe. then turn the power on , but do not let the boiler run on either water or heating . let it sit for a spell and if the fuse does not blow simply replace the head of the pump, which is easier than replacing the complete pump. remember yuor not allowed to touch the gas train.
Apr 26, 2009 | Water Heaters
Boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Oct 08, 2008 | Water Heaters
Water Heaters Logo
105 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
