Question about Aiwa CDC-Z127 CD Player
No volume Radio came with truck. No response when trying to use the vol/bass/tre/bal/fad control. I've tried the reset and restore factory settings with no luck. Thanx in advance... Danno kd5ceu@yahoo.com
  • GROUNDSBILLY Feb 02, 2009
    VOLUME DOES NOT CHANGE. I ASSUME THE KNOB (DIAL) IS WHAT CONTROLS THE VOULME AND THAT DOES NOT DO ANYTHING.
I have the same problem, it works occasionly when I move the unit around, I think it has something to do with the chasi ground, Right now I have it set decently loud to the point were I can hear the music over other noises, when I hit he power button it lowers enough to talk of a cell phone or have a conversation in the car, its not a fix, but it works as a temporary solution
Posted on Sep 22, 2007
My tv volume is locked how i can release panasonic Tc 2101
Try to reset the TV to factory defaults:
1. Get the original Panasonic TV remote control.
2. Press and HOLD the volume-down button on the TV itself (not on the remote)
3. While you're holding the VOL- button on the TV, point the remote to the TV and press OK
This should do a soft-reset (most of your setting will stay).
If this doesn't work, try a full reset: Repeat the above steps; however, press the MENU button on the remote, while holding the VOL- button on the TV.
Note: When you do the full reset, the TV will lose all it's settings and customization that you did. It will go back to its out-of-the-box state.
Mar 15, 2016 | Panasonic Televison & Video
Grandson used pass word and forgot password, now I can't unlock tablet.
Try resetting it by holding down the power button for 10 seconds.that would shut it down. Restart then try logging in. Try to factory reset using the combination buttons as listed below
look for a tiny reset pinhole along the case it may reset the tablet too All RESETTING Ways Below Holding Down Certain Sequence of Keys or Buttons will put Most Tablets or Android Phones in Service mode to Factory Restore to New.
Hold Vol + & Power 20 sec
Hold Vol - & Power 20 sec
Hold Vol + - & Power 20 sec
Hold Home & Power 20 Sec
Hold Vol + & home & Power 20 sec
Hold vol - & home & power 20 sec
Hold Vol + - & Home & Power 20
Dec 12, 2014 | Tablets & eReaders
How to restore to factory default
To perform an External Manual Reset of your handset to restore to factory settings, read instructions below and then perform.
  1. Power off the phone, press and hold volume down button, press power button.
  2. Screen will come up with "Fastboot", press Vol down key to cycle through choices until you get"Android Recovery", then press Vol up key
  3. Wait for the "triangle ! / Android" screen then go on to step 4
  4. Tap on bottom right corner of the screen (may take a few times). a menu will come up
  5. Tap on "wipe data/factory reset", and tap OK. Another Confirmation screen will come. Tap Yesand OK
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. Tap OK.
  7. Phone will reboot to initial setup MOTOBLUR screen.
Tip: Once you've reset your device, you can use your existing account to sync your contacts back to the phone.
(Steps on Gingerbread 2.3)
Remove and remount the battery and power up
If the phone still does not boot up to the MOTOBLUR screen, then perform the following Factory Reset instructions:
  1. Power off the phone, press and hold the Volume down button and Power buttonsimultaneously while powering up the unit.
  2. Screen will come up with "Fastboot" at the top of the screen, press Volume down key to cycle through choices until you get "Android Recovery", then press Volume up key to boot in this mode
  3. Wait for the "triangle ! / Android" screen then go on to step 4 android_recoveryscrn.png
  4. Press both Volume up and Volume down key simultaneously. A Recovery Menu will come up
  5. Tap on Volume down key until "wipe data/factory reset" is highlighted, and tap Power button. Another Confirmation screen will come. Tap on Volume down key until coming to Yes and tapPower button
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. TapPower button
To Perform a Factory Data Reset through settings menu:
  1. From the Home screen, press Menu
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset (Read notes for other options)
  5. Touch Reset Phone
  6. Touch Erase Everything
Oct 20, 2014 | Samsung Cell Phones
Will not charge
My grandson forgot his password for his Nextbook Tablet, how can I unlock the screen to rest his password.
Jan 11, 2014 | Nextbook Premium 8 Se Android
How to restore back to factory settings
Try powering it up with the power button, and the volume buttons (both vol up and vol down) - all 3 pressed simultaneously. Hold them until it either boots, or gives you the option to restore to factory settings. This is a common method with tablets, but I have not used the pandigital.
Mar 19, 2013 | PANDIGITAL Novel 7
I have a CDC-X504MP. How do I get the fade control. I was in the truck when I bought it. Works great.
To get to the sound settings: Press and hold the Volume knob down. Press the "Seek" button until you see "Fad" on the display It will be between "Bal" and "LPF" Turn the volume knob to adjust
Jul 23, 2011 | Aiwa CDC-X504MP CD Player
I have a jensen cd6112 radio vol control is not working also will not change bass/tre/ or speakers.Tried reset button but no change .Vol knob won't do anything.
I was installing a speaker and while drilling a spark flew. Didn't think anything of it and finished instalation. When finished the audio didn't work on any of my speakers. I have a jensen cd6112 and the unit seemed to be fine. Tuned in, the lights came on and everything. I hooked a radio straight to the speakers to see if they were blown and they worked fine. Is there a fuse in line with the speaker wires? I would hat to buy another jensen unit and the same problem exist. Any help? Is the jensen unit bad?
Jan 05, 2010 | Jensen Car Audio & Video
DE1103
you should try pushing the reset hole with a unfolded paper clip, or leaving the batteries out of the unit overnight
Jun 11, 2008 | Kaito KA1103 SW/FM/AM Radio
BOOM BOOM BOOM
The Bose engineers in their "infinite" wisdom developed a $300 radio with no, that is NO, tone control. This means the only way to tune bass response is to reposition the Wave radio itself. If you put it in a corner of a room, it will produce the most bass. If it is only against one wall, not so much bass. To reduce bass response to a minimum, you would have to suspend the device from a wire in the middle of the room. Good luck. I would never buy a radio without a tone control; I literally inherited by Bose Wave Radio and use external speakers which do have tone controls.
Jun 10, 2008 | Bose Wave Radio
KENWOOD KDC 3024 IN CAR COMPACT DISC PLAYER
If you press and hold the audio button it will come up with Bas then use the am and fm to change to mid/ tre/ bal/fad hope this help
Jan 26, 2007 | Kenwood KDC-3024 CD Player
Aiwa CDC-Z127 CD Player Logo
105 people viewed this question
Top Aiwa Car Audio & Video Experts
Greg Cann
Greg Cann
fordexpert
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
