Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
GE Profile PDW8280J10SS: Water won't drain. I
GE Profile PDW8280J10SS: Water won't drain. I don't see any gunk at drain spot. Not sure what to do next.
  • 1,031 Answers
Can you get the water to drain at all in any cycle? If you can, then its possibly the control module .
If you can't get it to drain in other cycles or when you cancel the cycle, then its a possible clog in the drain outlet hose, drain solenoid, or screens.
Here is a good detailed link to check out that explains about it:
http://www.applianceaid.com/gedishdrain.html
Heres another link about general dishwasher draining issues:
http://www.applianceaid.com/drain_wash.html#drain
Posted on Apr 16, 2009
Refrigerator drain tube
Hi Joe:
Look at the back of the refridgerator. Typically you will be able to see the drain tube running don the back and into an evap tray underneath. Sometimes the drain tube will get plugged with nasty stuff at the evap tray, or inside the fridge at the drain entry. Cleaning the components, and blowing through the tube to make sure it is clear should solve the problems.
Mar 19, 2015 | GE Profile PFS22MIW
STANDING WATER UNDER DELI TRAY
Try going further than defrost and draining the hose. There is gunk that builds up and you need to clean that out. Use a pipe cleaner(the fuzzy wires used mostly for art projects. They actually can clean pipes and water lines!!) Also, you can pick up a pack of pellets used for breaking down the "gunk" build up.
Mar 06, 2014 | GE Profile : PFSF6PKXWW 25.5 cu.ft. Bottom...
Drain tube blocked in freezer GE profile PDS22MCRBWW
This is a result of the drain being clogged. you'll have to locate the drain hole in the bottom of the freezer. Remove the wire bins and gently poke around the back of the floor of the refer with your finger. You should be able to feel a soft spot and clear the drain with a Q-tip or something else soft and flexable.
Dec 17, 2012 | GE Profile PDS22SCRL Stainless Steel...
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Dishwasher won't drain. I made sure the sink drain were clear I don't have a Air Gap. Is there a way to check the drain inside the disherwasher. It started a couple days ago
I would check for obstruction in the drain hose.Take the drain hose off the garbage disposer hold it as low as you can over a pan or bucket and see if the dishwasher will drain centrifugally.If it does I would assume the pump is bad or disconnected.Possibly a utensil jamming it.
May 07, 2011 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher stops running and won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
hhf
May 13, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Dishwasher pdw8280j10ss
clean pump and check fins on impeller..may need pump kit
Aug 06, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Ge profile washing machine overflow
Check that the spigot where the Air Dome connects is also clean, it may be full of gunk so the dome gets no water/air pressure...
Apr 09, 2017 | Maytag Neptune FAV6800AW Top Load Washer
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
1,031 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
