Getting an error code of C6030
I am getting an error code of c6030 on my Kyocera km c3232e I need help on what it is and how to fix it!
KM-5050 error code displaying C 6030 how can i remove this code WebRepOverall ratingThis site has no rating(not enough votes)
Posted on Feb 07, 2013
mysticus_tam
  • 38 Answers
SOURCE: Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
Posted on Dec 21, 2009
anantakumarj
  • 330 Answers
SOURCE: kyocera KM 1525 COPIER Showing C630 error
check the fuser unit thermistor and replace it......
Posted on Oct 07, 2009
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
SOURCE: I need to reset ID Code on Kyocera Mita KM-5530
The solution is easy! Push the Default Setting/Counter button on the top right side of the keyboard. Press the the Managment icon on the diplay. Enter 6-4-8-2 on the keyboard and select the Managment icon in the OFF position. Close all windows on the display and you should be ready to go.
Posted on Jun 18, 2009
How can i fix error code cfb31 which appears on my kyocera km-4050 printer
Just generally CF-B31 firmware errors can be caused by a bad CODE DIMM, main board, or operation panel.
Try loading new firmware ...
Aug 21, 2015 | Kyocera Km-4050 With Feed, Fax, Finisher,...
What is C6030 on Kyocera Km-C2520
6030 Broken fuser thermistor M wire
*35/37 and 45/47 ppm printers (EUR/
USA model) only
Input from fuser thermistor M is less than
1 (A/D value) for more than 3 s.
Poor contact in the
fuser thermistor M
connector terminals.
Reinsert the connector (See page P.1-5-19).
Broken fuser
thermistor M wire./from the manual try replacing thermistors then reset the code or just replace fuser then reset the code
from the manual sadjnbdsvknsdlkvnsdv
Apr 12, 2014 | Kyocera FS-2000D Laser Printer
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Jan 27, 2011 | Kyocera Copystar CS-5035 Copier
C6030 error code
FUSER UNIT ***'Y PROBLEM NEED TO REST THE ERROR CODE
Sep 01, 2010 | Copystar CS-4035 Copier
I have a copystar c2520 and am getting a c6000 error which was cleared with 10871087 and then 163 but now im getting a c6030 code and it will not clear. could this be that the fuser is no good?
C6000, С6030 is Abnormally high temperature in the fixing section – The fixing unit thermistor output voltage remains less than 0.5 V for longer than 1 s, indicating the fixing temperature rises above 536F this may be the fuser is no good. Sorry? coll to Servise center Mita. Dood lack!
Sep 22, 2009 | Copystar Office Equipment & Supplies
ERROR CODE C630 ON KYOCERA KM-1510
this is a fuser error meaning that the fuser has overheated. In most cases the thermal fuse or thermostat blows and will need replacing. especially if you get the 630 code, and switch the machine of and back on and get a 610 code.
Oct 13, 2008 | Kyocera KM-1510 Copier
We have a Kyocera KM - C3232E an error came up after making a copy of C6100 is there anyway we can fix this issue without calling anyone
Only a quaified Kyocera technician can access the service mode. It sounds like you may have a fuser problem.
Try this, press status key, enter 10871087, 906 execute (print), 001 print takes you back to READY
or turn off and on again.
Sep 23, 2008 | Kyocera Office Equipment & Supplies
3,483 people viewed this question
jasbo
jasbo
