Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
88 mtd mower wont go past third gear
Mower is 7 speed wont get past third gear
  • John C Bridgers Sr May 11, 2010
    Hello rhondat61:
    >>From your Description it Sounds like the Shifter Linkage and Slider Requires Lubrication.
    >>Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
    Thanks.
    Respectfully
    jbridger (John)
  • 45 Answers
Without knowing the model, or type of transmission, I can only suggest checking your owners manual.
You can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Posted on Aug 25, 2009
MTD RIDING MOWER MODEL 13AH660F372
Your model is a shift on the go or varidrive. Not a transmission in the true sense . I have had to give the variable pulley a few shots of oil to get the pulley to work freely up and down.This video will help you understand the workings of your drive unit. How the MTD Varidrive system works Variable Speed Pulley Maintenance
May 30, 2016 | Mtd Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Rideon was under flood idrain engine oil do i have drain gaer and biff oil as well. and what oil do i replace gear oil with.
Yes, you do have to drain the gearbox and diff as well, because the oil in them will also have water in it. For the gearbox, use SAE 90, Gear oil. The diff will use the same oil. Don't forget to clean or replace the spark plug, and clean the Carby.
May 02, 2015 | Mtd Yard Machines 38-Inch 12.5 HP...
What sizes are the drive belt and mower belt on a 1999 agway mtd riding mower with a 12.5 hp briggs?
go to any lawn mower shop they will tell you and get you your belts 45.00 to 60.00 for a belt
Aug 11, 2014 | Mtd Yard Machines 38-Inch 12.5 HP...
Removed the deck on my Poulan pro to replace the sheared pins on the broken spindle. Now the mower wont go into gear?
You might have knocked the drive belt off while removing the deck/belt? what kind of transmission do you have 6 speed manual or an automatic?
May 16, 2014 | Mtd Garden
Hi i just bought a second hand MTD C4510 ride on mower yesterday, and the drive belt came off , where can i view a diagram to fit it so it can drive forward etc
u should have two drive belts .go to nearest seller of mtd ,get owners manual .u can'not push foot speed lever to quicky up & down .start to learn how to use your mower slowly .there is no gear box for forward & reverse speed. but u have forward & reverse gearbox .talk to your dealer he will explain
Dec 10, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
I have an MTD mower tha tis ver jerky in forward, reverse is fine. What could it be? The trans is about 2 years old. I thisnk it could be the clutch plate or the differentital, however, reverse works fine...
Assuming that the model you have is a single speed transmission with variable speed belt system and that the mower has never been used to tow anything heavier than a dump cart. 9 times out of 10 its usually the forward gear shift key not allowing it to go all the way into forward gear. Might be able to ajd the shift linkage to acomodate a tighter mesh with the input and ring gear
Nov 23, 2009 | Mtd Garden
Ride on mower drive problem
sounds like a belt to me not tight enough against the pullys
Nov 09, 2009 | Mtd Gold 42" Zero-Turn Mower -
MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Jun 28, 2009 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
How to ajust drive belt on a mtd riding mower
Adjust in gear 7. If you try to adjjust in gear 1 you will get it to tight and it wont work properly
Apr 14, 2009 | Mtd Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
224 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
