Question about Infinity BASSLINK Car Subwoofer
Sub is blowing fuses!! :(
My basslink sub stopped working a few months back. There was no power at all. I decided to troubleshoot it today and found a blown fuse. I went to the store and picked up another 20A blade fuse. The sub finally powered on. However there was still no audio. The power LED was solid and the Servo LED would fade in and out gradually. 5 second fade in, 5 second fade out, approx. I unplugged everything and plugged it all back in and bam. No power. Checked the fuse and it was blown. What's the most likely reason that this would happen?
  • mat4 Apr 16, 2009
    I'm not sure what this piece is called, but it's on what would, essentially, be the motherboard. It charred near the bottom.
    Now I'm not sure about the audio aspect, but as far as blowing fuses, I can kind of assume why.
    Why would I get no audio, though? The sub powers on (with a new fuse) for approx 30 seconds. During those 30 seconds it stays silent and then the fuse will blow.
    Could the charred peice just be problem #2 on top of a pre-existing problem?
    Here are the pics.
    Thanks for the help so far.
    Scholar:
  • 34 Answers
The issue is most likely a short in the amp internal circutry where power is essentially flowing without resistance acrosss the short. You may or may not have sound or crackling noise as it depends on where the short is.
If you are electronically inclined, I suggest the folliowing:
- disconnect all power and open the amp up
- look for any burn marks around the circut board and parts.
- first focus in on the area where the power comes in - see if any diodes (black cylinders with stripes on them) are burnt / cracked
- next have a look at all the MOSFETS. These should be 3-legged components and will likely be mounted to the shell or heatsink. Look for any burn marks or cracks on these.
- also look for any wire or component that may be shorting other components. Generally all wires should have shielding and all components should be soldered firmly. Anything crossing other components could be a problem.
If you find any burnt/cracked components, they will need to be replaced.
Here is a sample image showing the MOSFET chips to the top and bottom on the aluminum rail.
http://memimage.cardomain.com/ride_images/3/2514/3981/31284490262_large.jpg
Posted on Apr 16, 2009
  • Dave Apr 17, 2009
    Its hard to tell from the images what the charred piece is - but looking at the area, Id say its in the power supply now. You have to pinpoint the burnt components. It could be as easy as finding the parts and replacing them. I think the reason why you get 30 seconds of life is because the charred component is shorted, but not completely. Essentially, its like a half broken dam, water is rushing out, but not all at once. If it were all at once, the fuse would blow immediately.
The capacitor in my amp blew in the same place, could be an increase in current caused by a bad amp transister.
I'm gonna put a larger voltage rated 1000uf capacitor @ 200 volts and repair the burnt circuit board trace that was vaporized. If the problems persist then it's most likely a bad power transister.
Posted on Dec 19, 2010
I have a Mirage Prestige S8 subwoofer. 4 years old. Suddenly nothing....not functioning. No change in usage or location. Any ideas?
Check the status indicator - The LED found on the front panel should be illuminate in blue when the subwoofer is functioning. If the unit is in Auto mode and is not receiving a signal, the light will remain off. Try setting the power switch on the back to ON if in the Auto setting. Post back the status of your LED.
Aug 31, 2011 | Mirage Prestige S8 Subwoofer Speaker
My sub stopped working today made a weird noise then cut out i had a 500w amp and 500w 10'' subtube i connected the sub to 3 other amp set ups all the amps work and power other subs but my sub wont make...
did you check the fuse if you have one on it. also u want to have more wattage on your speakers than your amp to protect from blowing your speakers.
Jul 29, 2010 | M-Audio Car Audio & Video
My basslink circuitry is fried!!
go to the website that built the part. they usually have manuls you can download and get exact part number.. then go to ebay or google t for fix andddd parts cosr
Feb 17, 2010 | Infinity BASSLINK Car Subwoofer
My sub woofer wont turn back on
Hello austin_optiz,
If you have had 2 units with the same problem, I'd say that yes, there is a problem with the "sound sensing" function of the auto turn-on circuit. Either it's not getting the correct level or one side is being shorted or grounded. Some vehicle speakers may have one side at ground potential which could cause the auto turn-on to fail.
If the Basslink operates normally otherwise, I'd recommend that you just connect a 12V + fused and switched source to the remote terminal. Wire it through a conveniently mounted toggle switch and turn it on and off manually.
Hope this helps.
Oct 14, 2009 | Infinity BASSLINK Car Subwoofer
Basslink works in 'on' but not when the engine is running
check your amps ground wire i had similar prob the vibration from engine caused the wire to move interupting the current
Jul 19, 2009 | Infinity BASSLINK Car Subwoofer
No sound..amp has power to it
Hello eric_sodergu,
**First thing is verifying that the powerlight is lite up, this shows that it is receiving power and is grounded properly.
**Next thing you need to ensure is that the remote wire is connected properly on both the head unit and the amp.
**Third Make sure the RCA wires are all connected properly, try jiggling them around on the amps end to make sure there not just shorting out.
**Check all fuses related to the amp to make sure all the channels are working properly. (Applys to amps with multiple channels and fuses)
If all these things are fine, then the sub could very well be blown. Did you have it up loud before it stopped working ? You said it was working fine then just went all quiet, did the head unit power down as well ?
Post back with any further info or questions so that I can assist you further.
Jul 17, 2009 | Infinity BASSLINK Car Subwoofer
Jvc th-c30
sharazanct I had the same problem and posted here many months ago without any success. Just today, believe it or not, I decided i would replace the screws in the top cover and try it one last time. I don't know why, but it now works fine.???? My original problem was my receiver would light up and appeared to be working but I would get no sound out of the sub or speakers. I noticed at the time when I would first turn the receiver on the green indicator light on the front of the sub would light for a couple of seconds and then go out and would get no sound. Today the sub light lit and stayed on and I'm therefore able to hear sound as if everything was normal. I wish I knew exactly what I did, unfortunately I don't. If you have everything back together you might try unplugging the receiver and sub for some amount of time and come back and try it again. Good Luck!
May 04, 2009 | JVC TH-C30 System
Phntom bass sounds
uhhh....try you change your wire setup
Sep 17, 2008 | Infinity BASSLINK Car Subwoofer
Infinity Basslink
That popping you hear is most likely the voice coil blown and your not going to get much out of it now. Discontinue use of the unit so it doesn't blow the amp, and you can get the sub replaced if you don't want to toss it.
Good luck, hope this helps
Aug 02, 2008 | Infinity BASSLINK Car Subwoofer
2nd Basslink, still no power-on. Please help
this is in response to the post below:
I just bot a basslink t and i wired it up and nothing it just keeps blowing the fues in the unit i got mine on ebay2.gif so i dont know if i can use the warranty dose anybody have an ida for me- britter623
I got a used basslink about a month ago and had the exact same prob kept blowing fuses...found out that the voice coil had blown on the infinity...so I had a brand new dvc polk 10 sittin in the closet, I swapped them out, put the polk in the place of the infinity sub, however, the magnet is much larger, hence, dual voice coil, it would rattle sooo much from the passive radiator against the magnet, also could not turn the gain up at all due to the rattle. I got the bright idea to build a "custom fiberglas enclosure for the polk and incorporate the infinity's parts(amp/control) I finished the box finally last night and hooked it up this morning, no power, no lights, no nothing! s@#%, F&@%! ANyone had a prob w/the amp not having the lights turn on, no power??? Hope that helps about your fuse blowing issue.
Jul 15, 2008 | Infinity BASSLINK Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
906 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
