CD won't eject. I've restarted and tried all the fixes recommended by MAC forums and so far no luck. Any other ideas?
CD refuses to come out of Mini MAC. I've tried all the recommended fixes and so far nothing has worked. Before I take it to a MAC store, any other good suggestions? I'd appreciate it! Lorraine
    Scholar:
  • 39 Answers
If it is just the computer that isn't ejecting the disk (and not a physically "stuck" DVD) there is a way to force eject.
Go to Apple menu > Restart and hold down your mouse button until the disk ejects.
Or you can try the firmware method...
If all other methods fail, you can try to eject the disk using the firmware (this may not work on all computers). To use this method, start up and briefly use the computer with only the firmware loaded, not the standard Mac OS X interface.
To eject a disc using firmware:
Restart the computer.
When you hear the startup sound, press and hold the Command-Option-O-F keys. (The Command key has an Apple on it.)
Release the keys when you see a white welcome screen.
At the prompt, type:
eject cd
Press Return, then wait a few seconds. The disc drive should eject the disc, and "ok" appears on the screen when the action is complete.
Type:
mac-boot
Press Return.
Your computer starts up normally and you see the familiar Mac OS X desktop.
Posted on Apr 16, 2009
How can the cd player be fixed when it won'r eject a cd on my Mac computer
try ejecting in Itunes. it has a eject button that sometimes overrides the player
Oct 26, 2012 | Apple iMac Computers & Internet
Can't install cd disk in mac mini. Won't go in.
Hi Roberta, do you have any small (or not so small for that matter) children?
Normally if a CD won't go in, then there is something else already in there - quite often a foreign object like a credit card, a Mini-CD or a biscuit!
When tyou insert your CD does it come to an abrupt stop or does it come to a soft spongey type stop? Does it make any noise?
If it's the former then there is probably something already in there.
Regardless of what happens I think you are heading towards a service centre to have it looked at.
Jan 18, 2012 | Computers & Internet
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
Aug 16, 2011 | Computers & Internet
My cd drive has got stuck inside my MAC Pc
try to eject it by click on menu it will need to try more than few times if it doesnt work restart your mac and try to eject from menu
good luck
Sep 18, 2010 | Apple MacBook Pro Notebook
Intel iMac: disk does not eject, does not mount, makes no noise
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here are some steps I recommend you try to resolve the issue with the disc not ejecting properly. Now you mentioned that you used the drutil tray open command- if that is correct, then for your Mac Mini, that will not work, because that command is for drives with trays only.
In your case, you have slot drive in your Mac Mini so try the command line that I have provided below. It is just a slight modification from what you stated you tried.
-EJECTING DISC USING TERMINAL-
From your Desktop:
•Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
• Locate and open the Terminal application.
• At prompt, type: drutil eject and press the Return key on your keyboard
(NOTE: If you have a CD/DVD drive with a tray, type: drutil tray open press the Return key on your keyboard).
If that procedure with Terminal does not work, there are two applications that you can try:
Disk Utility- You open the application, select the affected disc or the optical drive in the left sidebar window. Then select eject from the top of the Disk Utility menu. See if that work.
iTunes- Simply open the application, and select the eject icon at the bottom of the window.
Last but not least, I did notice you did not mention that you try this procedure:
Reboot your Mac Mini.
As the Mac Mini boots up, hold down all mouse buttons and keep holding them down until (hopefully) the cd ejects.
I am not sure if you have done all of these processes for ejecting your disc, but again these steps were not mentioned in your initial inquiry.
Let me know if these additional steps have helped or if they are in fact redundant.
Regards,
-Mactechtrainer
Feb 02, 2010 | Apple Mac mini
I put a mini disk in my macbook not knowing it would not load - now it will not eject
Be persistant-shake the F&^% out of it. Face it with the disk slot facing down and just shake it a few times. Worked for me.
Sep 15, 2009 | Computers & Internet
CDs get stuck in the slot of my mac mini---3 years old.
Ok, let's go through the options in case you have missed one. Command E, Open Finder and click eject button next too it's name, dragging the item to trash, press F12, or hitting eject on the keyboard. If none of those work make sure the drive is not just busy. Sometimes you have to wait a few seconds even after stopping the application. You can use Disk Utility in Applications/Utilities to eject a CD. Open Terminal and type drutil tray eject If that fails, in Terminal type drutil list and then look at the list and find the drive. Tyoe drutil tray eject 1 The 1 should be replace with whatever drive # you found in the list.
Aug 05, 2009 | Apple Mac mini G4 Desktop
Can't eject Install CD Mac OSX Panther
Hi GInette, sorry to hear you are having problems,
here is how you eject a disk that is stuck in the optical drive of a Mac.
Shut down the Mac.
press the power on button
VERY QUICKLY, press the mouse button, the trackpad button and hold it down firmly until the disk ejects.
This is a built-in hardware command independent of your system and always works when doe right, unless the optical drive is no longer recognized by the Mac or if something is inhibiting it's ejection.
Good luck
Mar 28, 2009 | Apple Computers & Internet
Mini cd stuck in my macbook
You can try this:
  1. Restart your Mac.
  2. After you hear the startup chime, press and hold your trackpad button.
  3. After a minute or so, and you think nothing is gonna happen, the disc ejects.
  4. Release the button once the disc ejects.
Mar 20, 2009 | Apple MacBook Pro Notebook
MacBook Force Eject CD
worked for me:
1)open Terminal
2)copy this into it:
diskutil unmount disk1
diskutil eject disk1
3)press enter
4)cd comes out
found here: http://condonethis.com/mac_eject/
Aug 11, 2008 | Apple MacBook Mac Notebook
Computers & Internet Logo
356 people viewed this question
David Payne
David Payne
