Question about Canon PowerShot S2 IS Digital Camera
Canon S2 IS LCD Screen Doesn't Work Correctly
Had a lot of trouble with this camera. Worked great in the beginning. The LCD screen started to **** out every now and then. Then after not using camera for a while i got the Black Screen problem. To my suprised it friggin worked!!!
Now the LCD screen doesnt work in the normal position for taking pictures. I works when i swivel the screen but having to take pictures like that is really annoying. Can anyone help?
  • 98 Answers
Hi, Some leads from the display wires are cracked or broken, if you are accurate enough you can replace it by yourself otherwise bring it to an repairshop.
regards Rob Rotronica
Posted on Apr 16, 2009
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/26928900@N00/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
S2 IS black screen of death
Yes there are a lot affected. But if you want to try fixing it yourself (without even opening the camera or touching screwdriver), consider trying the following.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 10, 2009 | Canon PowerShot S2 IS Digital Camera
I have no image in the viewfinder on a canon S2 IS but the lcd display works and it seems to work fine otherwise. What are the likely causes?
There is sometimes a button on digital cameras that turns off the LCD while taking pictures to save battery. Does your camera have a viewfinder? If it does then there might be a button that looks like a little screen or says "disp" or something like that.
Jun 12, 2009 | Canon PowerShot S2 IS Digital Camera
Canon S2 IS problem blank viewfinder and LCD
some cameras have the choice to take the picture by looking through the veiwfinder or on the LCD screen. check in the menu and set it to LCD if you want to use the LCD
Mar 21, 2009 | Canon PowerShot S2 IS Digital Camera
BLACK SCREEN
I have the same problem with my Canon S3 IS. I was about to buy a new camera and somehow bumped into this post. I tried this solution twice and it WORKS. Thanks a lot.
Sep 30, 2008 | Canon PowerShot S2 IS Digital Camera
Black screen
Piece of junk that took great pictures for 1 year and now shows a black screen. Do not buy any Canon products. We also have one of these pieces of junk at work, now displays a E 18 code. Appears Canon wants to make mucho dollars by producing ****.
Apr 13, 2008 | Canon PowerShot S2 IS Digital Camera
Canon S2 problems
Low battery power ? (rechargeables do not last forever).
Try a brand new set of batteries
Feb 06, 2008 | Canon PowerShot S2 IS Digital Camera
Canon S3 no display on LCD screen
This is a common problem that we ( in the camera repair game ) see a lot . The cause is faulty CCD sensor ( see enclosed pic from a Canon camera ) to see what I mean . Canon will repair this ( or replace the camera if they cannot repair it inside 4 weeks ) free of charge. Why does this happen ? Badly manufactured ( produced in 2002-2004 run ) sensor goes in the camera and starts outputting noise after 1 or 2 years instead of working properly for +- 10 years.8abdb4c.jpg
Dec 05, 2007 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
301 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
