Question about Ricoh RDC-7 Digital Camera
Error message I was switching out of no flash option on my camera when it displayed "error 21-01-02-20-10. What does this mean?
I have light in this ( !) what that is mean?
If ! light displays a solid light it means that the printer front door is open, print cartridge is missing, or a flash option has been installed that is not supported. Please Close the door, install a print cartridge, or install a supported flash option. The printer will automatically reset.
If ! light and Continue button (green button) displays a solid light, it means a printer error. The printer memory is too full to collate the print job. To continue printing press and release continue button to clear the message. To cancel press and release the X (red button).
You may also press Continue button twice quickly to see the secondary error code. For further assistance, please call Lexmark Technical Support.
Jun 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
What does FEE mean? The camera won't take a picture and I see that in the display of my Nikon N90S
FEE error message displayed on SLR camera LCD Description If the cameras LCD screen displays "FEE" in the area where the aperture is normally displayed, please ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens such as the Nikon AF or Nikkor P lenses. Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
The FEE error message
Set to F22, or the highest aperture number - normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experence the the error display FEE, please contact your local Nikon office. Before doing so please also check the following.
1157d.gif That the EE servo coupling highlighted above on the lenses has not been broken. That the F-min switch highlighted above on the camera body has not been broken. If either of the two items above are broken please contact your local Nikon service center.
Apr 19, 2011 | Nikon N90S 35mm SLR Camera
After I loaded the film, there is an error message flashing and an "E" on the display. I changed the aperture to the minimum (highest number), but that did nothing.
If you are getting an error message, check the lens to see if it is seated properly, and check the little switch at the bottom of the lens to see if it is switched up.
Jan 04, 2011 | Nikon N80 35mm SLR Camera
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
Nikon D70 with brand new Sandik ultra11 2gb flash card error CHR
Go to the Nikon site and upgrade the firmware on your D70 to version 2.0.
Before doing that, try turning the camera off, wait a min, then back on. That sometimes clears the error. The D70 is having trouble reading the card(s) you're putting in. The upgrade fixes that.
Mar 09, 2009 | Nikon D70 Digital Camera with 18-70mm Lens
ON MY DISPLAY
Hi
This is normally a problem with the flash. Try resetting all the options to default through the menu... I think Sony calls it 'initialize' but I don't have a W35 on hand to walk through the steps sorry.
Hopefully this will work. If not, you will have to replace the flash, but you may still have to clear the error message after replacing the flash and that takes specialized equipment.
Good luck
Thomas
Oct 03, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Hi I have a sony cyber shot dsc t20 and I get an error message flash settings cannot be changed whe I try and select another flash setting?
I had the same problem, and i tryed everything, even opening
the camera and see if any visible damage on any part (nothing), so
when i try initializing again ( menu>setup>option #1), right after the
"OK" over reseated date, i went to the Flash Button, and turn it off
and at least the annoying flashing error is not there - that means it is
software error, because all flash functions work till it detects that
has ans error wile charging/loading the flash. Hope it helps.
TENFERRE
Aug 25, 2008 | Sony Cameras
I have a canon 400d eos digital camara, and when i try to use an error message is displayed error 05 the built in flashes auto pop up was obstructed i have attempted to turn off and on without success...
There is a little switch that tells the camera if the flash is up or down. if your flash is up and you get this message then the switch is eather damaged, a tab is broke or the mainboard is acting up. Thing are a pain let me know if I can help you any further. Hope this helps
Jul 03, 2008 | Canon Cameras
Error message is F--
Well, it looks that FE message means that the camera is confused. I saw this message when I put a non-D lens and automatic TTL flash  (which does require D lens to measure a distance). Usually putting the camera (or flash in my case) into manual mode got rid of the error.
Jul 03, 2008 | Fuji FinePix S2 Pro Digital Camera
Ricoh RDC-7 Digital Camera Logo
Top Ricoh Cameras Experts
Tony
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
