Question about Vacuums
Pump doesn't work
My Galaxy 2000 Carpet Cleaner will not spray the solution onto the carpet. It worked fine on the first tank, but when I refilled the tank it would not start spraying again
Remove the sprayer at the end of the wand clean the tip with a needle then replace
Posted on May 01, 2009
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
Tip
Bissel Carpet Cleaner Won't Dispense Water
"My Bissel carpet cleaner has little to no spray action".
This is a common problem and here are some Trouble Shooting solutions. If your machine is only dispensing a little bit of water, or none at all, then:
1. The bladder may be empty- Turn power off, remove tank and refill.
2. The lent screen may be clogged- Clean out the lent screen.
3. Tank-In-Tank may not be seated properly- Turn power off; remove tank and reseat tank.
4. The pump belt may be broken- If so, replace with a new one. The belt can usually be accessed through a belt access door on the top-side of your machine.
Here is a Link that will help in your search for the right belt:
vacuumcleanershop.com/
Good Luck!
If you should have any questions about"Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power- HAND TOOLS" at FixYa.com
I will do my best to answer your questions about drywall finishing. However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
Thanks for looking,
Jim
Key Words: Carpet Cleaning, Rug, Steamer, & Stains
on Oct 08, 2010 | Vacuums
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
Bissell Power wash /powerbrush sprays the carpet ok ,but when empty doesn't fill up with any dirty water from the carpet .Is there anything I am not doing correctly
It sounds like the suction isn't working right. Check the dirt tank to make sure it is on correct and check the red plastic filter on the dirt tank to make sure that it isn't clogged.
Dec 02, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell carpet shampooer won't spray out water
The tubes inside the machine are probably clogged. Dismantle top hood and disconnect the three lines at the pump, open up entire top housing and inspect heater. Disconnect two tubes and heater and blow out with air compressor. That will spray all the junk, soap that has built up and your machine will be good as new. If you can't do this yourself, contact bissell and ask where your local repair center is
Aug 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Cleaner was working fine. Emptied the recovery
yes please help0. my carpet is soaked and the machine will not **** up the water
Jul 03, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell carpet cleaner not spraying water out of bladder
my bissell machine was bought 2nd hand and I can see where to put the water in...too complicated...anyone have the bissell proheat pro-tech with scotchgard i believe the model # is 010-5458
May 08, 2008 | Vacuums
Eureka Atlantis 2591A Extractor - Won't spray
Hard to say without seeing it, is there a function type knob that you would switch from carpet to hose? Did the hose attachment lid close ok? Other then take, if this is new, it has a years warranty on it, just take it to a waranty shop for repair.
Apr 20, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Vacuums Logo
110 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
