The button feels right when pressed but there is no audible beep and it will not change screens. All other buttons work fine and it charges properly.
SOURCE: garmin forerunner 301
hi
the garmin gps often use a soft rubber in their contruction
either wait til the unit is out of the heat or use a bit more pressure to push the button doen firmly
the map60 range has the same issue with the power on/off buttons
there is no replacement parts as its built into the case
D
SOURCE: GARMIN 305 Forerunner wont transfer data to PC
For Pc users:
Go to Garmin website Updates & Downloads, Training Centre for Windows software version 3.4.1, click on download.
I previously deleted all saved couses on Training Centre, but don't know if this is relevant.
SOURCE: Forerunner 305 won't charge
Had the same problem. Turned out I only *thought* it was the cradle and/or cable being finicky. Actually, the problem was one of the four contact points on the back of the 305 had oxidized and if all 4 don't make good contact with the cradle, it won't charge. Apparently, manipulating the cable only coincidentally helped, if/when it did help, perhaps by subtly shifting the contact point so that a less oxidized part made contact.
Anyway, rubbing the contact points with a pencil eraser cleans them enough to get a good charge. I've had to break out the eraser every 2-4 weeks.
SOURCE: Garmin forerunner 305
Will it start up whilst in the cradle, charging?
Mine did, but will not charge up off the cradle. Turned out to be a duff battery/connections due to water getting into the device!
F_P
SOURCE: My Garmin forerunner 305 will not turn on.
I have had the same problem. To fix it, I simultaneously hold down the "mode" and "reset" buttons for about 10 seconds. After releasing the buttons I power it up as normal. This has worked both times it has happened, and I got this fix from the Garmin website. My mileage totals are still in the history.
